What engine for 1958 cj5 - JeepForum.com
post #1 of 3 Old 04-20-2009, 06:21 AM Thread Starter
XtreemJeeper
I have a CJ5 that needs an engine. I am not looking to find and drop the stock 4 in there. I was hoping someone may know about an engine that I could put in without too much modification. I hear everyone putting in these 350s. Someone said I may be able to drop the straight 6 in. Can I put anything in with a new mount kit?
Thanks for any help
XtreemJeeper is offline
post #2 of 3 Old 04-20-2009, 06:33 AM
mcmud
1983 CJ8
Not enough length between the firewall and grille for the I6. Choices would be limited to the I4, V8 or a V6.
mcmud is offline
post #3 of 3 Old 04-20-2009, 09:10 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
What is the ultimate goal of your build?
1) F-134 would be stock resto
2) A late model 2.5EFI could have a stockish appearance if done right, but with twice the HP and the convenience of fuel injection
3) Buick V6 was a factory option from '67 to '71 and still a popular swap option. Although the original were 225 odd fire, 231 even fire are widely available and have a similar external appearance.
4) Buick V8, especially 350 Buick, will fit if you're looking for something bigger. The benefit of this engine is the forward dist location. Late CJ grille and 304 radiator make installation easy, or there are aftermarket options.
5) Ford 302 or SBC will fit, but more modifications and aftermarket parts are required than with the Buick.
6) Straight 6 will not fit without cutting a hole in the firewall and sliding the engine back, or putting a postal grille on the front. There are too many better swap options available to seriously consider this route.
7) VW Rabbit Turbo Diesel is an awesome swap option that fits like a glove, but rebuildable cores are like Hen's teeth, and runners fetch a mint.
8) Ford 4cyl "Pinto" engines were popular back in the day, but I think the late TJ 2.5 mentioned above would be even better for the EFI.
9) Christian Hazel of JP Magazine put a late GM V6 (3400?) crate engine in his flat fender. Although the late model engines are designed for FWD cars, you can use an older 60deg Camaro/Firebird/S10 bellhousing as an adapter.
10) There is a board member Scott Milliner at www.earlycj5.com that swapped in a GM-based OMC boat engine complete. Nice looking swap and very practical for an offroad environment.
My '70 CJ5 Build Thread:
jayhawkclint is offline
So I found a 1958 Willys 4x4 wagon, thoughts? SuB8HaVeN Jeep CJ Forum 23 07-02-2009 01:02 PM
Seats for a 1958 CJ-5 SuB8HaVeN Jeep CJ Forum 6 02-18-2008 09:56 AM
Automatic Transmission 1958 CJ7 kbuss32 Jeep CJ Forum 5 02-05-2008 02:59 PM
Rebuilt engine is sucking air into engine other than through the carb cj7_79 Jeep CJ Forum 4 12-11-2005 07:32 PM
1958 willys CJ5 for 480$ soler Jeep CJ Forum 1 05-10-2003 02:24 PM
