What does the ignition lps fuse link to? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > What does the ignition lps fuse link to?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shippRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 04-19-2014, 12:21 PM   #1
chrisdj1992
I replaced my battery and alternator yesterday and I (as they say in ghost busters) crossed the streams. I connected the positive cable to the negative terminal and vise versa. I think I caught it and removed them before anything was damaged but in my rush to get them off I touched my wrench to the fire wall and sparks flew. Long story short I blew the ignition lps fuse. Obviously the jeep won't start (cranks but no ignition) but my radio, and fuel gauge stopped working as well. Is this typical af a blown ignition fuse or should I be looking for something else as well? Also what can be damaged as a result of crossing the streams?
chrisdj1992 is offline   Reply With Quote Quick reply to this message
Unread 04-19-2014, 12:29 PM   #2
Dngrs1
1979 CJ7
Replace the fuse and see. I bet that would have made a funny Youtube video.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline   Reply With Quote Quick reply to this message
Unread 04-19-2014, 01:01 PM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
That is the ignition and dash lamp fuse. Likely the gauges too.
If it still won't run after a new fuse, check the fuse link wires on the fender solenoid.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 04-20-2014, 06:55 PM   #4
chrisdj1992
Yes I'm sure it would ha ha! I replaced the fuses (turns out the radio fuse was blown as well) started up great, then It died later after replacing the alternator and no luck I realized that the wire that runs from the alternator to the solenoid had broken so I reconnected it now it's running like new!
Fitting that my jeep would die on Friday and then be resurrected today
Unread 04-20-2014, 08:26 PM   #5
Mike Romain
If the wire that broke is right by the fender solenoid, that is s fuse link. You need to replace it with fuse link wire or a 60 amp fuse. It is there for fire protection in case of a short.
Parts stores usually sell fuse link wire by the foot. You need 14 ga fuse link for the alternator circuit.
Mike
