What do you guys think? - Page 2 - JeepForum.com
post #16 of 22 Old 09-07-2011, 02:40 PM Thread Starter
MosesYJ
1987 YJ Wrangler
Thanks guys all i could find was buick skylark info it was the same but now im double sure
MosesYJ is offline
post #17 of 22 Old 09-07-2011, 03:00 PM Thread Starter
MosesYJ
1987 YJ Wrangler
Now i gotta go chase the bees out and get to work on it , update hopefully tonight
MosesYJ is offline
post #18 of 22 Old 09-10-2011, 11:24 AM Thread Starter
MosesYJ
1987 YJ Wrangler
ok good news, i changed the spark plugs, wires, and wasn't getting spark, so i pulled the distributor and set the points and tried turning it over, still wasnt getting spark so i twisted the distributor around till i was getting spark, poured some gas in the old carb and she fired right up, running strong and has good oil pressure. so now i have to check the gas tank for leaks and set up a fuel pump.
MosesYJ is offline
post #19 of 22 Old 09-10-2011, 10:17 PM Thread Starter
MosesYJ
1987 YJ Wrangler
got the fuel lines ran, got the pump mounted got it runnin, need to fix the timing, any ideas if its 6 or 12 volt?, i think its 12 because it dosent have a generator it has a alternator, tell me what u think
MosesYJ is offline
post #20 of 22 Old 09-11-2011, 07:17 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Engine:
New cap, rotor, plugs, points, and condenser. Be sure to recheck the timing when your done setting the dwell. A great upgrade is an HEI ignition from a 76 Apollo with the 231 ODDFIRE. Speaking of the oddfire, do some research on the engine, as it has some ignition quirks you should be aware of.
Your CJ has an alternator upgrade. That is a good thing, however, I would dump the cheesy air cleaner for a larger, fully enclosed unit.
Most of this can be done with the body removed for easier access, however, I would solve any steering issues before pulling it.
It is a 12 volt system. Your currently running a delco internally regulated alternator, which isn't stock. It is however, a cheaper, and in my opinion, better replacement.
Back to your timing, Insure your rotor is under the #1 tower on the cap. While it will run if it isn't, it won't be right and you can have some frustrating times trying to sort out weak cylinders and misses.
jeepdaddy2000 is offline
post #21 of 22 Old 09-11-2011, 07:20 AM
jeepdaddy2000
1971 CJ5
Dear Lord,
I just hit the edit instead of the quote button and screwed up my first post!
Now THAT takes brains
post #22 of 22 Old 09-11-2011, 09:24 AM Thread Starter
MosesYJ
1987 YJ Wrangler
thanks
MosesYJ is offline
cj , dauntless
Hey CJ guys! Vassago Jeep CJ Forum 11 01-22-2010 10:11 AM
Do you guys know where i can get one of these? drunkenrich Jeep CJ Forum 11 10-01-2009 04:03 PM
What do you guys think? MHSJEEPKID2012 Jeep CJ Forum 15 08-07-2009 09:18 AM
What do you guys think? drunkenrich Jeep CJ Forum 15 03-11-2008 09:56 AM
Something for you CJ guys. ixl4 Jeep CJ Forum 4 03-02-2005 12:13 PM
