What to do with a 1960 willys pickup - JeepForum.com
post #1 of 12 Old 10-10-2009, 08:50 AM Thread Starter
corysean99
I have had this pickup since 99. I is a PITA, it would foul plugs everytime I drove it. Only would do 35 tops. It has been sitting now for 8 years since I last messed with it. It has the original 226 flat head, t-90, dana/spicer 18, dana 53 rear and 20 something up front. It has Rancho springs up front and sit on about a 33" buckshot. I would love to build it but everything is so weak. Would a 258 with some up graded axles be a wheelin machine? I dont want to do the ole set the body on a blazer frame type of thing. i want it to stay as pure as a jeep as possible. Is there any use for the ild flathead 6s out there? I took it out wheel once with my brother and his cj-5. It took hours to get to where we were going but the truck performed great for wat it is.
Would you keep it stock? Mod it? sell it and build the cj-5? Any thoughts would be great
Thanks
corysean99 is offline
post #2 of 12 Old 10-10-2009, 09:09 AM
danheit
danheit's Avatar
1979 CJ7
I would sell it....to me, and go buy something else! Seriously though, It can be easily built for little money. As long as the frame is solid, the body isn't rotting apart, and the wiring doesn't look like a squirrel nest, I would find a 4.0HO (or even a lighter 5.0 mustang motor), upgrade the tranny and throw some axles at it and be done. Great wheeler after that IMO.
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!!
Build Thread: 1979 CJ7
danheit is offline
post #3 of 12 Old 10-10-2009, 01:53 PM
Cutlass327
1978 CJ5
35mph tops? It's not stuck in low range is it?
Rick
Cutlass327 is offline
post #4 of 12 Old 10-10-2009, 08:58 PM
duffer
1955 CJ3B
The 226 must be really hammered if it tops at 35. The 226 normally would push the pickup at least 2x that speed. They have much more torque than the 134 and should perform relatively well off road. As for a build up, both the pickups and wagons offer much more for component selection than the cj's due to their long wheelbase. There will be minimal driveshaft issues.
duffer is offline
post #5 of 12 Old 10-10-2009, 10:00 PM
sanddrag
Clearly this truck is at the end of its useful life. You should just give it to me and I will dispose of it properly.
sanddrag is offline
post #6 of 12 Old 10-10-2009, 10:10 PM
Comanche_
Build it. Those are cool lil trucks.
Comanche_ is offline
post #7 of 12 Old 10-11-2009, 01:01 AM
Cutlass327
1978 CJ5
Got any pics?
Rick
post #8 of 12 Old 10-11-2009, 09:07 AM Thread Starter
corysean99
I will get some pics. It has been sitting at my parents house since I bought it the summer after high school. I am prettty sure the engine needs work, is why it wont go over 35. That is the first and only flat head engine I have ever tried to work on. Any suggestions on how to make it run better. Though I am sure by now the engine is toast.
post #9 of 12 Old 10-11-2009, 09:49 AM
80cj
80cj's Avatar
1980 CJ5
The Dana Spicer 53 rearend should hold up fairly well. It has a bigger ring gear than a 44 but I believe it still uses the 1.25 x 19 spline axles that 44's of that period used. The plantations here used a lot of those trucks and I've seen them take quite a bit of abuse. The 226 doesn't have enough power to break things, I guess. A small Chevy V-8 (283, 305, 307) works well with the stock drive train. A Warn overdive works well with a V-8 conversion. The front axle should be a Dana Spicer 25. Common rearend ratio I believe was 4.89.
80cj is offline
post #10 of 12 Old 10-11-2009, 05:13 PM
IDK
Yeah I'd upgrade the axles and throw a V8 in it and call it good if I was you. That's what we're going to do with a 46 flat fender if we buy it, I got all the stuff to put a small block Chevy in it and some better axles. The stock L head will then be transferred into my little brother's 57 CJ5, the old F head in it is played out and to expensive to restore.
IDK is offline
post #11 of 12 Old 10-11-2009, 06:01 PM Thread Starter
corysean99
I really would like to put some beefier axles and more reliable engine in it but my problem is do I throw money into a truck that would take some work just to get it able to drive or take that money and put into the 79 cj-5 that runs strong. I feel I would be into the willys for a lot more money.
post #12 of 12 Old 10-11-2009, 06:34 PM
Skotter
Unless you're prepared to have TWO "projects" with the cj and the Willys, sell the Willys and use the $$ for your cj. Otherwise, you'll continually be trying to spend a little here and a little there, never able to fully dedicate to one or the other. If you're retired and lots of money, then fix up both. If you're not, sell one. There may be a big difference between what we would like to do and what we are capable of doing.
Skotter is offline
1960 Willys starving itself of gas,HELP? ga-peach60 Jeep CJ Forum 9 06-25-2009 03:24 PM
52 Willys Jeep Pickup Build Plan HAARUBICON Jeep CJ Forum 11 05-27-2009 01:18 PM
1960 willys cj5 F Head Bigger tires and wheels? 2002fordgt Jeep CJ Forum 3 05-05-2009 12:18 AM
1951 willys pickup truck wheelchairman Jeep CJ Forum 2 03-20-2007 07:34 PM
