What is the difference in the front and rear shackles - JeepForum.com
post #1 of 5 Old 11-01-2009, 12:11 AM Thread Starter
bigpapa18205
i am looking to buy some half inch lift shackles from a friend, they are for a wrangler... online i read they will only fit the rear on a cj... does anybody know why,,,,, can they be modified?
bigpapa18205 is offline
post #2 of 5 Old 11-01-2009, 08:44 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If the shackles have a "cross brace" welded between them, and they are designed for YJ springs, then they'll be too wide to use up front on a CJ. The CJ front springs are only 2" wide while the YJ's are 2.5" wide.
You could cut out the center brace and weld/bolt in a narrower one... or not use a cross brace at all.
BESRK is offline
post #3 of 5 Old 11-01-2009, 09:14 AM
Mike Romain
Stock YJ shackles work fine front and rear, the 1.2" isn't enough to screw up the steering too much, it does make a bit of a difference in the self centering though..
Mike
Mike Romain is offline
post #4 of 5 Old 11-01-2009, 10:15 AM Thread Starter
bigpapa18205
can i just put 1/4 inch of washers on either side to fill in the gap and to have them centered?
post #5 of 5 Old 11-01-2009, 10:39 AM
Mike Romain
Well,,,, Yes I guess. The longer bolt is likely to put a lot of stress on the bushing I would think.
Mike
Front shackles moving.... woody-77 Jeep CJ Forum 18 04-20-2007 09:16 PM
front tow shackles.. Mr.Crowley Jeep CJ Forum 7 03-15-2007 10:55 PM
Front Shackles jrejle Jeep CJ Forum 3 08-05-2002 10:45 PM
1983 CJ7 OEM Shackles Front and Rear, same size?? fLeXyJeEp Jeep CJ Forum 1 04-14-2002 07:47 AM
Need 1980 CJ5 Stock Shackles front and rear scottahicks Jeep CJ Forum 3 03-17-2002 10:42 PM
