What Diff Cover do you use? DANA 30 - JeepForum.com
post #1 of 13 Old 06-14-2013, 12:35 PM Thread Starter
DirtyCJ7
Hi all,
I have a 84 CJ7, with the DANA 30. I just installed lockers and gears and want to seal it up with a good quality Diff Cover. I was going to install a Xtream Cover made out of aluminum to match the one on the rear, however due to the material thickness and the close proximity of the steering dampener I don't think it will work. Any Suggestions for an alternative?
Thanks
Your Off Road Accessory Outlet
DirtyCJ7 is offline
post #2 of 13 Old 06-14-2013, 12:40 PM
Destr0
I run an ARB Cover and in the rough stuff it will touch the steering - only enough to scratch the paint. It is a good 1/4" thick steel.
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #3 of 13 Old 06-14-2013, 12:58 PM
CSP
Not a Dana 30 on mine, but I use Crane covers.
CSP is offline
post #4 of 13 Old 06-14-2013, 07:06 PM
82JeepCJ7
1982 CJ7
Hard to beat the stock, thick diff cover. They often hold up better than the aftermarket covers.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 13 Old 06-14-2013, 07:11 PM
MoC
Plus they are cheap if you beat one up..
MoC is offline
post #6 of 13 Old 06-14-2013, 07:30 PM
mvigo
mvigo's Avatar
I have Riddlers on my Dana 30 and my AMC 20...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #7 of 13 Old 06-14-2013, 11:46 PM
LumpyGrits
Alum. covers and rocks are a very pour choice.
Stay with steel.....
LG
LumpyGrits is offline
post #8 of 13 Old 06-15-2013, 12:43 AM
titomars
1981 CJ7
ARB's front and rear on mine.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #9 of 13 Old 06-15-2013, 10:54 AM
brownbagg
1930 MK Compass
use the one that came with it, its just as good, at least better than the aluminum one
brownbagg is offline
post #10 of 13 Old 06-15-2013, 11:48 AM
holliewood61
holliewood61's Avatar
1981 CJ7
BTF makes a pretty stout cover as well
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #11 of 13 Old 06-15-2013, 04:06 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
LG
I agree. Unless your going for some sparkle, the steel ones will take a hit better, not chunk out, can be welded when damaged, and are cheaper to boot.
jeepdaddy2000 is offline
post #12 of 13 Old 06-16-2013, 12:10 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Yeah, I'd rather have one that would dent on a rock than split open on said rock... You can still move with a dent (usually), but split open means no more oil...
Rick
Cutlass327 is online now
post #13 of 13 Old 06-16-2013, 12:32 PM
lucdog
1980 CJ5
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
cj7 , dana 30 , diff cover , differential cover
