What did you do to your CJ today? - Page 755 - JeepForum.com
 795Likes
post #11311 of 22467 Old 01-27-2013, 10:02 PM
twinstickd20
1979 CJ7
Originally Posted by 82JeepCJ7
Built a traction bar for the rear to keep the spring wrap down.
Axle side mount.
I added cross bracing to keep it all square and add strength.
All welds were TIG welded. I used 4130 Chrome-Moly to keep the size down.
T-case end mount was mocked up then welded into place.
Axle mount welded into place.
Bar is all clean and ready for paint.
Masking removed from the bushings.
Main eye bushing was pressed in.
Shackle mount all welded out and painted. All that is left is to put the shackle on and its done. It is currently drying in the oven
(don't tell the wife)
I'm about to have to do the same thing because mine is about to trash some fairly new ome xj springs
My Build Thread
twinstickd20 is offline
post #11312 of 22467 Old 01-28-2013, 03:37 AM
nshefbuch
1982 CJ7
I'm surprised 82jeep didn't slant it back on the axle to gain ground clearance. Make the top bar longer and angle the bracket on the axle twinstickd20.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #11313 of 22467 Old 01-28-2013, 05:37 AM
gazzo
Originally Posted by WSS View Post
A very special Xmas present to be sure. The Jeep won't fit in your pocket but the knife can't take you up the mountain, so you surely need both LOL Is it a assisted opener? Looks fast.
Got my cage welded this weekend!
Bet it feels nice showing off those yummy welds. Got your machine dialed in real nice there. Good work!
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline
post #11314 of 22467 Old 01-28-2013, 09:05 AM
82JeepCJ7
1982 CJ7
Any time you do a link style setup, a percentage of it needs to be below the axle centerline.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #11315 of 22467 Old 01-28-2013, 10:54 AM
nshefbuch
1982 CJ7
Ahh. Didn't know that. Thanks. I hasn't researched link setups much.
post #11316 of 22467 Old 01-28-2013, 11:49 AM
MojoMark
Got my York compressor mounted on the engine and driven with the serpentine belt. Next up making all the connections for the OBA project.
MojoMark
1986 CJ7, 4.2 I6, T5
D300, 2" Lift, 33" Tires
D30 Front (Aussie Locker), AMC 20
MojoMark is offline
post #11317 of 22467 Old 01-29-2013, 05:03 PM
skizriz
1978 CJ7
Pulled the belly pan off of my Jeep to make a template to transfer to the new frame. The new frame looked like Swiss cheese from all of the mounting holes drilled in it, and being a frame from a newer year, none of the holes were what I needed.
Pulled the pan, and found my transfer case mount was completely broken. I guess that would explain the recent klunking I was feeling while pulling out.
I had a new one on the shelf I picked up but never installed yet.
A little worn out????
Cut a piece off a roll of body mount rubber I had laying around for the snubber part. I had to work with what I had at the time. I just need a few more months out of it until teardown time.
Wrestled the belly pan back on dropping nuts into the access holes the PO had cut in the frame. Took a while, and a lot of cussing, something I'm trying to avoid in the future.
Plugged up most of the unused holes in the new frame and welded them up. I left three 5/8 holes in each side for water drainage.
Drilled three new 1/2 holes and fished 3/8 bolts through the frame. Welded them in place for studs for the pan. Should be as easy as a wire brush and some PB Blaster to remove it in the future.
skizriz is online now
post #11318 of 22467 Old 01-29-2013, 08:26 PM
Dadamsnv
1977 CJ5
Killer work man! You should start "skizriz's super tech thread"
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is online now
post #11319 of 22467 Old 01-29-2013, 08:37 PM
8pitcher
8pitcher's Avatar
X2 man.
Very nice frame work.
sent from the bottom of an empty money pit
8pitcher is offline
post #11320 of 22467 Old 01-29-2013, 08:40 PM
Backcountry
Did ford shock mounts with long travel ranchos!
Backcountry is offline
post #11321 of 22467 Old 01-29-2013, 08:49 PM
Lifted96ZJ
1973 CJ5
Attachment 553871
what size lift with those? And are you on stock axles?
Build Thread
http://www.jeepforum.com/forum/f8/1973-cj5-trail-rig-hunting-rig-build-1403107/
Lifted96ZJ is offline
post #11322 of 22467 Old 01-29-2013, 09:06 PM
Backcountry
Yes 30 front 20 rear, those are 35x12.50 pitbulls, 4 inch suspension 2 body, thats a 32 inch shock, huuugee improvement over stock an cheap also I can take better pics in daylight if you like
post #11323 of 22467 Old 01-29-2013, 09:11 PM
Lifted96ZJ
1973 CJ5
Yeah definitely. Thinking of doing something like that also.
Build Thread
post #11324 of 22467 Old 01-29-2013, 09:22 PM
Backcountry
The mounts are 13 dollars a piece from ford
post #11325 of 22467 Old 01-29-2013, 09:26 PM
gmgreen
1983 CJ7
Drove it around for a while today.
gmgreen is offline
Got another CJ today!! fastas69 Jeep CJ Forum 9 03-01-2016 07:12 AM
What Did You Do To Your CJ Today? Renegade86 Jeep CJ Forum 4 08-01-2010 09:31 PM
Nutter'ed my 84 CJ7 2.5 today! 79cherokee Jeep CJ Forum 2 10-11-2008 10:06 AM
I just got my first CJ5 today! bannings Jeep CJ Forum 12 08-11-2004 08:52 PM
got my cj-5 today....:D supersly_jones Jeep CJ Forum 11 06-17-2004 07:32 PM
