#61 | |
tried to bolt up the flex plate to my new (to me) 258 and found that the theads were stripped in one hole. gonna try some permatex thread repair tomarrow. i also pulled out my AC evaporator and blower motor. im converting my pump to a air compressor.
#62 |
took the top and doors off....it finally got above 50
in Va today |
#63 | |
Vulcan FTW
Took off the super enormous WARN sticker which was on the hood from the PO....looks much better now.
Gone but not forgotten: '86 CJ7, '06 Wrangler X, '03 Rubicon, '97 Wrangler, '77 CJ5, '74 CJ5(RIP)...gone and forgotten: 07 JK Sahara Unlimited, '78 CJ5 Quote:
#64 | ||
(that was easily the biggest sticker I'd ever seen on a Jeep) Hoss
Don't mind me, I'm just another FNG around here...
#65 |
What was I thinking
Took my plow off, I guess it will snow now.
#66 |
I installed a brand new rear driveshaft. Put on a new glovebox door and grab bar. The jeep did not come with them and now the glovebox door hits the grab bar.
It seems that I am missing a dash brace. Good day Bad day:suicide: |
#67 | ||
Vulcan FTW
Yes....it took 3 hours to get it....and I agree it was the biggest sticker I have ever seen on a Jeep The sticker was kind of baked on the hood from the heat of the engine so even with using a hair dryer to make it more plyable it still would rip every inch or so... I tried WD40 and Goo Gone on the sticky stuff after I got the sticker off, neither worked very well so after an hour or so of messing with that my wife suggested one of those magic erasers....it worked like a charm....took 4 of them to get all the sticky off. I buffed the hood with Zymol cleaner wax and put a coat of Meguires Show car polish on it....looks brand new.
#68 | |
Turned the garage light on, looked at it sitting there half torn down, on jacks. Sighed, turned the light off. Went back to figuring out how to buy "must need" parts as cheap as possible.
Marching or fighting, it all pays the same. Quote:
#69 |
PB Blasted the body bushing bolts and suspension parts, getting ready for a 2 1/2" lift and polyurethane bushings. Seafoamed the carb.
'83 CJ-7 Renegade......258, Holley 390, Offy Intake, Clifford 6 into 2 Headers, Clifford Cam, Juicebox TFI, LUK Pro Gold Clutch, Flowmaster Hushpower II's, 4 row radiator, 20 gallon tank, and blazer heater motor so far!! |
#70 | |
double-checked the coffee can that is stiing under my Jeep which is catching the gear-oil that is dripping from my leaking trans/t-case...
Hoss
#71 |
I went and pushed on the brake pedal to see if the brakes decided to fix themselves. They did not sadly so I guess I will be trying to determine which wheel cylinder is bad and fixing it. Jeez.
J |
#72 |
CV driveshaft
Sure glad CJ owners still wave.. '82 CJ7 360, T-5, M20 and D30 w/Tru-Trac's, 4.5", 33's '06 WRX STI '95 Honda Prelude V-Tec '97 Mazda Millenia DD '71 240Z project |
#73 |
Removed the ignition switch so I could gain access to the brake light switch to adjust it. Had to remove the spring on the brake pedal to reach the switch. Got the switch adjusted but am now having
installing the spring. |
#74 |
What a bad day I had..finshed up mt heater core install,took it for a ride after letting it warm up and checking for leaks,and low and behold when I got back it was gushing worse than before..Disgusted with the 7,I pulled the scrambler out of the car port,and I forgot I used a tie down to hold the rear of the carport down to the rear bumper of ther scrammy...BANG whent the back of the carport...It now has a custom fastback look to it...all in all a good day
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1 1984 cj8 350 on 35's..the wifes [QUOTE=Me] "offroad it, and wave then you might understand"[/QUOTE] BLS Home Chapter... Where it all Started :hahaha: yj My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL] |
#75 | |
Nom Nom Nom
Man, I laughed out loud when I read that. I dont know why but thats pretty funny. I can completely relate. Ive been hoping my oil leak would fix itself for a while now... cheers ![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
