Today? How 'bout since I bought it? I keep a spreadsheet. (yes, a little type-A, I know)
September 23, 2006 Removed decals (L&R rear quarters), removed tub trim and adhesive, replaced taillight covers/back-up bulb, replaced both front side marker bulbs, and welded set-screws on shifter arm, adjusted clutch.
September 24, 2006 Oil/filter change, cleaned/oiled air filter, replaced PCV valve, repaired/welded spare-tire bracket, and removed visors/brackets.
September 25, 2006 Repaired exhaust /replaced muffler/hangers/tailpipe.
September 26, 2006 Removed air-pump tubes/brackets, replaced battery hold-down, new bolts/ driver's side motor mount, and reattached motor ground, welded cap for exhaust.
September 28, 2006 Replaced rusted/missing horn ring with '93 YJ set-up.
October 31, 2006 Replaced passenger-side motor-mount, repaired horn, and replaced defrost indicator on dash.
November 6, 2006 Temp repair to bell crank shaft, ordered new bushings. Installed new shift boot, tightened shifter knob. Removed stock steps from driver/pass side.
November 14, 2006 Removed non-working interior AC unit, including fan. Removed A/C plug under dash, and cleaned up wiring.
December 1, 2006 Mounted and balanced 'new' solid aluminum rims, including spare.
December 5, 2006 Replaced fuel filter, installed new fuel pressure regulator and set @ 3.5 PSI (Weber recommended). Removed non-working radio.
December 8, 2006 Replaced spare tire stop and hardware.
December 19, 2006 Replaced hood hold-downs, windshield bumpers, and footman loops on hood.
December 22, 2006 Replaced stock passenger side seat with Rampage model, welded driver side floor mount, fabricated drivers-side seat slide adjuster, and ground-down slide bolts.
January 4, 2007 Installed new wiper knob, removed factory dash speakers, purchased chrome grill surround.
January 9, 2007 Installed 'new' 32x11.5x15 spare tire, and installed new rear license plate frame/plate cover.
January 25, 2007 Installed new Clarion dash speakers, repaired antennae base and installed 'new' antennae, cut-out opening, wired and installed 'new' Pioneer stereo.
January 29, 2007 Installed new floor drain plugs and bolts to fill factory step holes, fab'd and installed new bumper bolts for spare tire mount.
January 30, 2007 Installed rear speaker wiring and MTX speaker box.
February 5, 2007 Installed 'new' center console, fab'd mounting brackets, and seat belt brackets.
February 13, 2007 Repaired broken zipper-pulls on left rear and back windows of soft-top.
February 23, 2007 Replaced front park/turn lenses and bulbs, painted interior housing. Replaced drivers front fender side marker lens. Drained and refilled trans/t-case fluid. Tightened t-case linkage nut. Trimmed and installed front and rear floor mats.
