What did you do to prep fiberglass body before installing? - JeepForum.com
post #1 of 93 Old 08-08-2012, 02:02 PM Thread Starter
Jeeprage
Jeeprage's Avatar
What work did you do, what cuts and holes did you make before installing a new glass body?
I undercoated mine, cut shifter floor hole (smaller than stock), firewall steering hole, brake hole, and electric harness pass through. I only have a yj tub to model after. Anything else I need to do before bolting the 4wd body on?
Not sure how precise heater core and blotter motor holes need to be.
2015 JKU - 6m
Jeeprage is offline
post #2 of 93 Old 08-09-2012, 11:56 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Anyone with this challenge or link to a detailed fiberglass tub install? 4wd install video was worthless.
2015 JKU - 6m
Jeeprage is offline
post #3 of 93 Old 08-09-2012, 06:33 PM
John Strenk
John Strenk's Avatar
1976 CJ5
The heater holes need to be damn accurate as there are no adjustments between the fresh air intake to the blower motor. Only thing flexible is the defrost.
It's a pain trying to get the heater in when the holes a a little off.
I would get a piece of cardboard and trace out the openings and mounting screws.
After cutting open new holes, put a layer of epoxy over it to seal the edges.
After I drilled holes for the frame mounts, I sealed those hole back up also so waster does not get in. Same with drain holes.
Drain holes?
Yeo. First time I got caught in a down pore, I quickly drilled two holes for drains. No un driving a bathtub around.
Don't forget speedometer cable hose and parking brake hose.
I tore the steel reinforcement plate off the old metal tub and bolted it on the fiberglass tub. Makes lining up brakes and steering column and firewall plug brake and lutch assembly very easy. Those spot welds pop easily and you hardly bend the reinforcement plate.
John Strenk is offline
post #4 of 93 Old 08-09-2012, 07:52 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
I had a lot of trouble being able to reaching thru the plastic to where I had to drill my holes in the floor. And it was a pain getting my old firewall (that I cut from my old tub)... bolted to the new tub, to use as a template.
Finally, when I went to my neighbors to borrow a holesaw for the body mounts, he suggested that I take it out of the wooden shipping cage!
Just follow Johns advice, you'll be fine. Measure 2x, cut once.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #5 of 93 Old 08-10-2012, 04:20 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Drain holes?
Thanks. My biggest challenge is that I don't have the original tub. I have a YJ tub only.
2015 JKU - 6m
Jeeprage is offline
post #6 of 93 Old 08-10-2012, 04:44 AM
John Strenk
1976 CJ5
Well a YJ uses the same heater as a CJ except for the 76 & 77 years.
post #7 of 93 Old 08-10-2012, 05:22 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Heater motor? What about the placement of core? I have both heater boxes too and planned to use stock with Chevy motor upgrade. I planned to cut holes and then drill bolt holes as needed.
2015 JKU - 6m
Jeeprage is offline
post #8 of 93 Old 08-10-2012, 08:01 AM
Skerr
This doesn't give dimensions, but it does show a labeled firewall. You would know what to expect.
http://www.jeepforum.com/forum/f8/an...ewall-1031195/
Kerrdog
Go Fish! <*////><
Skerr is offline
post #9 of 93 Old 08-10-2012, 08:06 AM
gmakra
Hutch are you saying that you "cut it twice and its still too short?"
gmakra is offline
post #10 of 93 Old 08-10-2012, 08:17 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Perfect. Did you drill bolt holes ahead of time too? Any logic to the color coding?
2015 JKU - 6m
Jeeprage is offline
post #11 of 93 Old 08-10-2012, 09:00 PM
Skerr
No logic to the color coding as I am aware of... probably justy to make it more distinguishable.
Our Jeep had a glass tub installed when we bought it. Everything the PO had mounted was already cut/drilled. However, I ended up closing up most of the holes, leaving only the main things like column, master cylinder, clutch. Everything else I drilled myself. There is no real magic or mystery to making the holes. Most of the time it's the shortest route, or the most efficient run. Don't get hung up on it. The things that MUST be correct are those that I mentioned, and I'll throw the fuse box in there. There was no heater box, and we didn't install one, so I am no help there.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #12 of 93 Old 08-11-2012, 04:16 AM
gmakra
I had heard that 4Wheel Parts used to have a template you could get from them.
gmakra is offline
post #13 of 93 Old 08-11-2012, 07:25 PM
paraman72
I used the cardboard template and it worked for the heater mounting the only pain was that the bolts are not long enough to go through. The only part I butchered was the clutch rod... oh well got some patching to do...
85 CJ7 Build in progress, 258 with T-5 and dana 300.
Fiberglass tub Raptor lined interior, rustoleum lined the underside. Modified family roll bar from fender mounted rollbar. Full tie ins to the frame soon to come.
paraman72 is offline
post #14 of 93 Old 08-11-2012, 07:32 PM
TJs83CJ7
I found the steering column difficult to line up. I installed the dash and then mounted the steering and pedals off of it. I have pictures somewhere that I will post.
TJs83CJ7 is offline
post #15 of 93 Old 08-11-2012, 07:41 PM
Skerr
If there is any way you can get a hold of the metal plate from the firewall, it will help you get things lined up. I'm talking about the plate that has the VIN tag riveted to it. If you need a picture of the firewall of my tub, with the plate installed, I'll be glad to post one up. Also, I have a spare plate.
Kerrdog
Go Fish! <*////><
Skerr is offline
