What did i break? - Page 4 - JeepForum.com
post #46 of 51 Old 03-08-2007, 10:20 AM
JeeperJohn
I would tend to agree that it is your one piece axles.
There is one more posability and that is the spider gears in your diff.
Before you buy any parts pop the rear cover and check it out.
JeeperJohn is offline
post #47 of 51 Old 03-08-2007, 10:26 AM Thread Starter
c17load83
everything looked fine when i took the diff cover off.
c17load83 is offline
post #48 of 51 Old 03-08-2007, 12:15 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
1 peice instructions..But take it with a grain of salt cuz the Mfg. might be different from yours
http://www.moab4x4parts.com/axles-ax...80_76_109.html
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #49 of 51 Old 03-10-2007, 06:29 PM Thread Starter
c17load83
axles in and checked good, thanks for all the help
post #50 of 51 Old 03-11-2007, 10:11 AM
wheelinjames
Question about the brake drum since I'm putting my new Superior one pieces in my CJ-7.
Does your axle have the 3 screw holes for the brake drum to be secured to the hub. Mine doesn't and the kit uses the threaded lug bolts that are not tapered at the base. Therefore the brake drum has some slop.
wheelinjames is offline
post #51 of 51 Old 03-11-2007, 03:40 PM Thread Starter
c17load83
mine was the same way
75 cj5 break upgrade xeroOTG Jeep CJ Forum 4 05-26-2009 11:29 AM
AMC 360 break-in procedure twmattox Jeep CJ Forum 3 05-13-2009 05:22 PM
Break In napoleoneight Jeep CJ Forum 3 06-14-2007 08:07 PM
break problem thantos858 Jeep CJ Forum 2 11-06-2006 01:43 PM
WOW! Took quite a break from here... quickdodge Jeep CJ Forum 5 01-23-2005 07:45 PM
