What is the correct paint for CJ center caps? - JeepForum.com
post #1 of 9 Old 04-08-2014, 11:22 AM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Clearly the original CJ center caps had some kind of black paint, but the 2 caps I have look like there might be a lighter area in the outermost ring. Does anyone have a good photo of an original center cap? If I repaint mine, I want them to look right.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #2 of 9 Old 04-08-2014, 11:59 AM
wm69
Good pictures here
http://www.cj-8.com/forum/showthread...ght=center+cap
wm69 is offline
post #3 of 9 Old 04-08-2014, 12:30 PM
only in a jeep cj
I use semi gloss black from Dupli-color engine paint. It goes on smooth, dries fast, has a great finish, and last. It looks just like the brochures.
All one shade, no outer ring.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 9 Old 04-08-2014, 12:38 PM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
What method did you use to mask off the lettering and the raised outer edge? I have read about using Chapstick. I think it might also work to just use paint thinner or acetone to carefully wipe the paint off the letters before it dries.
Ken4444 is offline
post #5 of 9 Old 04-08-2014, 12:52 PM
only in a jeep cj
I don't use anything like chapstick. I paint the whole top with the spray direction going off the far edge so I don't have to mask the sides. I use brake cleaner on a rag and immediately wipe off the top outer chrome. For the letters, I wait for about an hour and use a cloth dipped in brake cleaner pulled tight on my finger tip OR a Q tip with brake cleaner and a rolling action to remove the paint.
Ed
1975 CJ-6 1983 CJ-8
post #6 of 9 Old 04-08-2014, 01:37 PM
Colt44
1983 CJ7
Same method, but I use Rustoleum Heavy Duty / Industrial semigloss black, acetone, a lint free cloth and q-tips. It's been 2 years without issue.
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline
post #7 of 9 Old 04-11-2014, 08:12 AM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I was finally able to see the pics from the post over at cj-8.com. The photos weren't designed specifically to show off the center caps, but they do give us an OK picture of what they should look like. The pics were fairly high resolution so these are crops showing just the center caps.
We can see that the black background should be continuous, as has been stated. There is some variation in the darkness, probably because these have not been repainted.
Jeep wagon wheel center cap closeup 1.jpg   Jeep wagon wheel center cap closeup 2.jpg
Ken4444 is offline
post #8 of 9 Old 04-11-2014, 08:15 AM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I have used Rustoleum Heavy Duty / Industrial semigloss black on many of my Jeep parts because it's not too expensive, dries quickly, and lasts a long time. I think I will use your exact same technique because I have this paint and a can of acetone in the garage. I just need to get a new roll of painter's tape so I can mask off the majority of the center caps before painting.
Ken4444 is offline
post #9 of 9 Old 04-11-2014, 01:26 PM
Colt44
1983 CJ7
Don't bother with the masking tape. You'll be spraying down on the caps and most of what misses will go off into the ether. It is quite simple to just wipe off the outside ring and whatever overspray is on the sides - and it taks a lot less time than masking. In fact, if you try to mask the ring you'll wind up with a pretty rough-looking circle (tried it). Wiping by hand with an acetone-dampened (lint free) cloth will allow you to trace the raised area and get a smooth curve. Then it's just a matter of giving the lettering a gentle wipe for the main areas, then folding and using a corner to get the tight spots. I had q-tips ready but actually didn't use them because the point of the folded cloth worked perfectly.
Colt44 is offline
