what is the correct oil pressure in a 258? - JeepForum.com
post #1 of 9 Old 09-28-2011, 08:04 AM Thread Starter
mulliflier
I read somewhere that it was higher than you would think, like 75 psi. Wondering what you shuld expect at idle and then at part throttle (about 2K RPM).
Just wanted to verify that so I can put some tape marks on my aftermarket gauge.
Thanks!
mulliflier is offline
post #2 of 9 Old 09-28-2011, 08:33 AM
keith460
Jeep. There's Only One
keith460's Avatar
FSM states: 13psi @ 600rpm (idle) and 37-75psi @ 1600+ rpm. 75psi max. Pressure relief valve will open after 75psi.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 9 Old 09-28-2011, 08:54 AM
zeronight
1982 CJ7
i normally have seen just over 10 at idle on my factory gauge and close to 35 at speed.
zeronight is offline
post #4 of 9 Old 09-28-2011, 08:57 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Mine idles at about 18-20 and 40-50 under load, on the factory gauge.
Matt
Matt1981CJ7 is offline
post #5 of 9 Old 09-28-2011, 01:15 PM
82JeepCJ7
1982 CJ7
10psi per 1000rpm is a good rule of thumb.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #6 of 9 Old 09-28-2011, 05:04 PM
Falcon_CMH
My CJ-7 starts cold at ~60-65 PSI idle. Then after it's warm it idles at ~20 PSI. Once the gas is applied it goes ~60-75 PSI depending on how much gas, steady gas it's at ~65 PSI. The RPM doesn't seem to matter. I recently replaced my rear main bearing seal (new oil pan seals all around too) and use 20w50 Castrol oil (white). I have a AMC 304.
Bought a 1980 CJ-7 that I am rebuilding ground up:
Given 6 hours to chop down a cherry tree a famous person once said I would sharpen my axe for 5 hours.
Falcon_CMH is offline
post #7 of 9 Old 09-28-2011, 07:49 PM
Nereussailor
I just rebuilt mine and it's running 35 at idle and 65 at 2000rpms after it's fully warmed up.
I'm not sure what tomorrow will bring, but it can't be any worse than what I've already been through.
Nereussailor is offline
post #8 of 9 Old 09-28-2011, 08:21 PM
BagusJeep
1981 CJ7
Gauge shows 45psi at speed but being a cheap piece of Chinese crap mechanical gauge who knows what it means. At least I get the pleasure of knowing the needle moves.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #9 of 9 Old 09-28-2011, 09:04 PM Thread Starter
mulliflier
Excellent, thanks for all the help guys!
Is it the oil pump, oil pressure sending unit or oil pressure gauge? 1sik78cj7 Jeep CJ Forum 5 09-08-2012 03:44 PM
Do I have this correct?? DUX4LIFE Jeep CJ Forum 6 08-12-2009 10:30 PM
Do I have this correct?? DUX4LIFE Jeep CJ Forum 0 08-11-2009 02:57 PM
Correct Oil Pressure CJ7 83 guru520 Jeep CJ Forum 6 12-02-2008 05:28 PM
correct oil pressure terp6977 Jeep CJ Forum 8 08-07-2006 09:54 AM
