What color is my Dana 300 transfer case?
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | |
Awww, APPLESAUCE!
Hi All - I am in the process of going through and checking out my transmission and transfer case. I am restoring it back to stock. My question is; What color do I paint my Dana 300 transfer case? It looks like it was black at one time, but I want to be sure. Also the t-case didn't leak, and as you can see, after I took off the transmission mount, and gentlly set it on the floor, the t-case developed a leak... I tried looking it over briefly, but I can't pick out where the leak is coming from.
1977 Jeep CJ7 Renegade, 304 V8, Torque Flite 999 automatic, Dana 300, AMC 20, Dana 30 front, 30" X 9.50" tires, building it back to stock.. A new work in progress, and a new lease on life... |
#2 |
black case with silver output shaft housings is what i've always seen on a dana300. as for your leak it's most likely coming from the oil pan on the under side of the case.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
