what clutch for sbc swap with gm 151 bellhousing? - JeepForum.com
post #1 of 9 Old 07-14-2010, 09:09 PM Thread Starter
rodjr
1980 CJ7
my sbc is here, motor mounts are here. need clutch. i have the iron duke bellhousing, 153 tooth flywheel, hydraulic clutch. my engine is from a 79 malibu, it had a 153 tooth, 10.4" clutch stock. can i just order one for a malibu? ive seen some pressure plates listed as high profile/low profile not sure which one i need, or if the stock one is high or low? help!
rodjr is offline
post #2 of 9 Old 07-14-2010, 11:26 PM
southshore30
1982 CJ7
You will need to order a throw out bearing for the Iron duke, use a 10.5" 10 spline GM clutch disk and pressure plate. They were used in 68/69 camaros and the early 80's Vette's and I'm sure a few more like your malibu. Diaphragham pressure plate Napa CA1897, and a Napa RCF 556 10.5" disc are the part numbers if you get them individually. I ordered them together. You will have to use a Iron Duke starter. You are right on about using the 153 tooth flywheel.
Just finished up w mine
Firefighters Jeep Club
SBC350,T-176,D-300,D44
southshore30 is offline
post #3 of 9 Old 07-15-2010, 12:12 AM Thread Starter
rodjr
1980 CJ7
thanks! i just went to napa online and sure nuf, 68 camaro is same part # as 80 malibu. ill order tomorrow!
rodjr is offline
post #4 of 9 Old 07-15-2010, 05:23 AM
cw4stein
1981 CJ7
It's all based on what transmission you're going to use. I have a 327 in mine with the iron duke BH and a Ford T-18a/D300. I ordered the pilot bearing from Novak that had the SBC outer diameter and the Ford inside diameter. The clutch disc was indeed a 10.5 inch, 10 spline but it had to be 1 and 1/16 for the T-18a instead of the 1 and 1/8 that was originally on the SR4. Double check the outside diameter of the input bearing retainer too. I had to order one from Novak for the T-18a that fit the bore size of the iron duke BH.
cw4stein is offline
post #5 of 9 Old 07-15-2010, 05:50 PM
southshore30
1982 CJ7
Yea, I didn't ask what trans you are using. I used a T-176 so I used the throwout bearing for the Iron duke with a T-176 trans. The pilot bearing that comes with the clutch is the right one. That is ithe 1 1/8" spline clutch I think.
post #6 of 9 Old 07-15-2010, 07:58 PM Thread Starter
rodjr
1980 CJ7
im using a t5, so 1 1/8 10 spline, same as chevy. i think the chev clutch should work, i was most worried about the pressure plate profile.
rodjr is offline
post #7 of 9 Old 07-15-2010, 11:16 PM
southshore30
1982 CJ7
It's not gonna take long to grenade that transmission! Why not start with something stronger? Can you find a T-176? Is that the trans the bellhousing is drilled for? Do some more research on that trans, its not going to hold up long.
post #8 of 9 Old 07-15-2010, 11:55 PM Thread Starter
rodjr
1980 CJ7
i am aware of the t5s weakness, however i intentionally sought out this particular engine for that reason, that and these engines got incredible mpg, made peak torque at 2000rpm, and ran super smooth. its a 1979 malibu 267ci (4.4l)v8, bone stock. its 125hp, 215 lbft. considering a stock 258 i6 makes 110-115hp and 210ish lbft, i think it will last a good bit. i only use the jeep as dd and some logging roads with a little snow here and there. i know a guy who has a t4 behind a 305 and its been there for 8 yrs. i know its a gamble but im gonna risk it.
rodjr is offline
post #9 of 9 Old 07-16-2010, 09:23 AM
CSP
Wow, there are still some of those engines around huh?
I had one in a 1980 Chevy Monza in high school. Great engine and lotsa people got surprised by the little car they assumed had a four cylinder in it.
CSP is offline
bellhousing , chevy , clutch , clutch fork , diaphragm , iron duke , pressure plate , t176 , throwout bearing
Clutch Problem!!! Throwout Lever Hits Bellhousing!! Hondaluvr1985 Jeep CJ Forum 10 01-10-2013 11:37 AM
4.0 swap clutch RockScar Jeep CJ Forum 2 05-02-2008 11:02 AM
Oil in my clutch bellhousing! joemac421 Jeep CJ Forum 17 01-22-2008 07:30 PM
bellhousing/clutch inspection plate Ezredcj Jeep CJ Forum 4 02-11-2006 08:08 PM
350 Swap Clutch? 5artist5 Jeep CJ Forum 1 05-10-2005 01:36 PM
