What clutch for my CJ - JeepForum.com
post #1 of 1 Old 03-04-2010, 03:39 AM Thread Starter
halvard
Hello all.
My clutch has started to slip, so I'm planning to replace it now before the wheeling season kicks of. My problem is that I am not sure which clutch will fit... It is a 85 CJ7. The original 258 has been swapped for a 304 by previous owner, origin unknown... The transmission is a T176, which I think is the original.
I have been reading up and think I am closing in... As far as I understand, I can use both 10.5" and 11" disc, and that it has to be 1 1/8 diameter shaft, 10 spline.
Can anyone confirm this?
4WD does not mention the diameter or spline count for their products... But I guess it will be OK when ordering for the correct year, as that depends on the transmission?
Any recommendations on which cluth kit to buy? The Jeep is used onroad and offroad. 33" tires. The engine has had some work done to it and is guestimated at 200HP.
Clutch Kit and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware
Clutch Kits - SummitRacing.com
Thanks
Halvard
85 CJ7 304 35"
halvard is offline
304 , cj7 , clutch , t176
hydraulic clutch - clutch won't disengage kercher Jeep CJ Forum 13 10-24-2009 12:27 PM
t150 clutch/t15a need correct clutch kit? speediemb Jeep CJ Forum 1 02-05-2009 10:52 PM
CJ clutch help vocky Jeep CJ Forum 2 07-21-2008 04:03 PM
Clutch works but I hear a whirring when I press the clutch pedal to the floor? part.changer Jeep CJ Forum 12 04-10-2007 03:31 PM
Clutch terry1956 Jeep CJ Forum 0 01-29-2005 08:42 AM
