What Clutch Master Cylinder ? - JeepForum.com
post #1 of 4 Old 03-20-2003, 08:27 AM Thread Starter
Scrambler82
Scrambler82's Avatar
1982 CJ8
I have installed a 5.0L Ford w/5 speed in my Bobed CJ-8 (Not Original) and need to setup the clutch operation. I have a stock for bellhousing and throwout arm and I have a stock Ford Slae Cylinder.
What Clutch Master Cylinder do I need to operate the Ford Slave ?
Or, do I need a new Slave cylinder as well ?
Any assist would be appreciated.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #2 of 4 Old 03-20-2003, 10:47 AM
Brandon Miller
I am using a toyota land cruiser one since I was told it was a long one - but really it is too short so I had to move the slave up on the arm to get it to work. Good luck
Brandon Miller
President of RCRC 4wd Club, Sacramento, CA
1993 ZJ. Rusty's BB and 30's. Otherwise stock. Yota with HD HP 44/60, 5.0/435/dual tcases etc etc.
Brandon Miller is offline
post #3 of 4 Old 03-20-2003, 03:49 PM Thread Starter
Scrambler82
1982 CJ8
Brandon,
Did you use the master cylinder from the YJ or from the Land Cruiser ?
You said you used the slave from teh Land Cruiser.
Thanks,
Scrambler82
post #4 of 4 Old 03-20-2003, 04:31 PM
Brandon Miller
both from the LC actually, but I also used the old cast bellhousing (kinda wish I used the other one now)
Brandon Miller
Clutch Master Cylinder phil77 Jeep CJ Forum 8 04-09-2010 09:38 PM
clutch: different bore size for master and slave cylinder kercher Jeep CJ Forum 0 10-09-2009 11:24 AM
Hyd Clutch swap, what master cylinder? BMac4x4 Jeep CJ Forum 12 08-02-2007 04:51 PM
Help, Clutch master cylinder problem my80cj5 Jeep CJ Forum 4 07-06-2006 10:17 AM
Clutch Master Cylinder Aphelion79 Jeep CJ Forum 2 06-28-2006 12:09 PM
