what brakes lines to get 86 cj7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > what brakes lines to get 86 cj7
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Wrangler WeatherstrippingJeep Wrangler Exhaust Manifold
Unread 04-05-2015, 04:42 AM   #1
fbergman
the beginning of a rebuild, what kind of brake lines to get, disc in front drum in rear , how to tell if try are standard or power disc ?
fbergman is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 07:19 AM   #2
HackFabrication
1976 CJ5
You have a vacuum booster, so you have power brakes. I got my lines from inlinetube.com. You can get them in stainless or regular steel.
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 07:27 AM   #3
Erik719
Erik719's Avatar
1983 CJ7
'86 you should have disks in front. You will see the shinny rotors. Rear you should have drums. You will see the rusty round metal things.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 07:35 AM   #4
agear
Get stainless steel brake lines. I got mine from quadratec made by classic tube. But let me tell you they are not an excellent fit. even though they were supposed to have been pre-bent for the jeep. I probably could have made them fit a little better by tweeking them some more myself but didn't think of that. I was also told that these pre bent lines are never a perfect fit so I don't know if another brand would have been a better fit
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 08:01 AM   #5
Agent_Orange
I went with over the counter straight soft steel and bent it myself with the tool. time consuming, yes... hard, not really. and for the average cost of around $2 per foot it was way inexpensive. can't wait to do it again in 5 years when these lines rust out!
Some guys think if they have a cool Rig they are better than other guys... and those guys are right!
Agent_Orange is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 08:23 AM   #6
HackFabrication
1976 CJ5
Originally Posted by Agent_Orange View Post
...can't wait to do it again in 5 years when these lines rust out!
The OEM ones lasted a lot of years. Stainless poses a number of issues, all surmountable, but none the less, issues. I did SS lines:
If I was to do it again, I'd just use regular steel. I doubt if I'll be still around in the 20-30 years it would take to rust regular steel lines out.
Unread 04-05-2015, 09:27 AM   #7
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I went with the prebent stainless lines and steel gas lines 5 years ago. The stainless still look new and the gas lines have rotted out and are leaking already.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 09:32 AM   #8
HackFabrication
1976 CJ5
Must be all that salt air...
Unread 04-05-2015, 12:03 PM   #9
Mike Romain
And the tons of salt they use on the roads.... We have a 2000 Cherokee literally with no floors left, the rear springs are up through the back seat. Had to jack it up and wedge a 2x4 between the inside roof and spring to get it home last time out.
Mike
Unread 04-05-2015, 12:30 PM   #10
HackFabrication
1976 CJ5
That's bad.
