What brake swap is this???? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > What brake swap is this????
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rock
Unread 06-16-2013, 12:52 PM   #1
Hitman87
Hey everyone, I just got a 1975 cj5 w/ 304ci. It had a brake swap done to it and I have no idea what they are off of. This jeep has been molested up and down! And there is all kinds of stuff changed around and swapped out. I guess I can't complaint too much since it was free! Here are some numbers I pulled off of the parts. Rt rotor 121.63004 or 6741 02-00. Rt caliper ST8G 3. The diff tag says 5350863 3 73 41-11. I just need to replace a caliper and master. Thanks
"If you seek peace, prepare for war!"
Hitman87 is offline   Reply With Quote
Unread 06-16-2013, 06:23 PM   #2
brownbagg
1930 MK Compass
its for a 77-79 cj7
http://www.partsgeek.com/gbproducts/...-05110615.html
brownbagg is offline   Reply With Quote
Unread 06-18-2013, 07:59 AM   #3
Hitman87
I spent hours and hours on the interweb and found that its is the Chevy truck disc brake conversion! It has an ssbc adjustable prop valve by the rear axle. I have to get a new master cyl and was wondering if I could use a YJ master and booster? Also how many prop valve do I need I thought two but I'm not sure?
Unread 06-18-2013, 10:15 AM   #4
CSP
That is indeed the Chevy (or Jeep) Dana 44 brake swap. The calipers and stands are off of a Jeep or Chevy Dana 44, the rotors would be '77/early 78 CJ thick rotors. I did the same swap on my '75 when it had the Dana 30 front axle. I used the stock master cylinder with the residual pressure valve for the front brakes removed. The stock prop. valve worked fine as the weight bias didn't change as a result of the disc brakes in front.
Prop valve just adjusts braking bias between front and rear, so only one is needed.
CSP is offline   Reply With Quote
Unread 06-18-2013, 11:24 AM   #5
Hitman87
I just bought a new master cylinder. How would you remove the residual valve
Unread 06-18-2013, 12:12 PM   #6
CSP
That depends on what master cylinder you purchased.
Unread 06-18-2013, 12:17 PM   #7
Hitman87
I just purchased an oem master for a 1975 cj5 with the 304
