What Bell Housing for a T-18? - JeepForum.com
post #1 of 11 Old 11-15-2012, 09:37 PM Thread Starter
mud4me
Hello,
Its been a while since I built this CJ and I need a refresher.
I have an 86 CJ7 with a 360 and AMC T-18 trans.
I recently had a problem with the trans and we had to pull it out. While it's out - the threads in the bell housing are not of the best condition. So I'm looking for another bell housing.
I believe there are TWO AMC bell housings for the T-18. One is the bellhousing used in the full size trucks (J-10, J-20), and the other is a shorter bell housing used in the CJ's?
Am I correct?
I have another bell housing, out of a J-20, but it is too tall.
So i believe my memory tells me that I needs a bell housing from a CJ.
Can anyone tell me what CJ bell housings will work with a 360 and T-18?
Thanks!
86 CJ-7, 360, Holley Avenger, T-18, Dana 20, 4" suspension,
mud4me is offline
post #2 of 11 Old 11-15-2012, 10:01 PM
8pitcher
8pitcher's Avatar
have one for the t18 that was cracked in about 15 spots. im going to use one from my old '83 cj7 that i parted that had a t4 they had different mounting for the tranny but bolts up from the 258 to my 304 just fine i just gotta drill and tap for my t 18.
make sense? if not let me know i just am not sure how to word it.
8pitcher is offline
post #3 of 11 Old 11-15-2012, 10:04 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
A T-150 will work as well. Did for me!
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #4 of 11 Old 11-15-2012, 10:12 PM Thread Starter
mud4me
Thats it, I have a bell housing out of a t-150.
Been about 8 or 9 years, so much has changed in my life since then (ie - a kid), that I couldnt remember. Tried to do a search but this fine forum wants money for an advanced search!
Thanks guys!
mud4me is offline
post #5 of 11 Old 11-15-2012, 10:13 PM
82JeepCJ7
1982 CJ7
A bell housing from a T4/5 will work fine as well. The index hole is the correct size. All you need to do is drill/tap the two lower holes. The materal is already there.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #6 of 11 Old 11-15-2012, 10:15 PM
8pitcher
8pitcher's Avatar
And he too holes they don't line up
8pitcher is offline
post #7 of 11 Old 11-15-2012, 10:47 PM
82JeepCJ7
1982 CJ7
The top holes lined up perfectly with my T-18.
post #8 of 11 Old 11-15-2012, 10:49 PM
8pitcher
8pitcher's Avatar
What why not for me? Maybe I have t18a?
8pitcher is offline
post #9 of 11 Old 11-15-2012, 10:55 PM
82JeepCJ7
1982 CJ7
Mine is a Ford T-18-1E
post #10 of 11 Old 11-15-2012, 11:09 PM
rixcj
rixcj's Avatar
1979 CJ5
You can use a t-150 or a t-176 bellhousing for a t-18, too.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #11 of 11 Old 11-16-2012, 04:53 PM
CSP
There are more than two version of the AMC T18 and I can think of four different bellhousings.
If it's a '76-79 CJ T18 the T150 and T18 shared the same bell as it had a dual pattern on it.
The '75 and older T18 has it's own bellhousing as well as both of the FSJ T18s (V8 version and I6) version.
The T4/T5 and T176 bells work with the Ford T18, but the lower left hole on the Jeep version is different than the Ford T18.
CSP is offline
