What to attach engine hoist to on 258?
| Rock Krawler Suspension's for BLOW OUT prices!!! | Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com |
#1 | |
Getting ready to pull out my 258. What do I attach the engine hoist to on the engine? Also should I unbolt thr t176 and dana 300 first or pull them as one unit?
#2 |
Hope this helps. I took off the alternator and used a bolt in the mounting location and then used a bolt hole that is right above exhaust manifold on the opposite side in the rear. Here is some pics.
![]() ![]() Craig |
#3 |
TrailWorthyFab.com
I unbolted the main bolt on the alt. and ran a link of the chain thru there. I also cliped it onto the other side. I pulled it all at once but I removed the front clip to do so. If you don't want to pull the front clip or at least the grill you will have to see how high you can get it and might have to use a strap to pull the tail up.
BUY IT DONT' BUILD IT!! You will be money and time ahead. (Flip off) |
#4 |
WTF is that?
Craigb's way is probably the safest, but I didn't have the leveler or a plate to attach to, so I did mine the Toxic way. I just used 2 ratchet straps strategically placed. Pull them all at once with the grill off, it'll take much less time than trying to separate them under the Jeep. I didn't do this, but will next time - Pull the grill and front fenders together as opposed to separate, it'll be much easier when installing everything back in. I had a tough time lining up the grill with the fenders - Next time they'll come off together.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift. AMC 20 Write Up In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles Coming Soon - CV Shafts, Welded Tubes, trusses |
#5 |
Anybody know the weight of the 258? Also the t176 and dana 300?
#6 |
I know that there are many way to do this... so if you guys could post more pics of how you lifted the engine out... I would be very greatful
#7 |
CJ OWNER FOR LIFE
I install engine/bellhousing/and transmission at same time....easier for me. left and right side shots.
I leave as much on the engine as possible, detach wires from engine, and pull vac lines and such from the body....use blocks or attachment points that don't crush fragile items and ![]() ![]()
Ed 1975 CJ-6 304 T15 Dana20 30/44 3.73 1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade 1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31 1986 TJ-7 Trail Jeep project in the works 2003 Inca Gold TJ Rubicon |
#8 |
#9 |
I attach my hoist to the head studs sticking out, just find two nuts that screw on, and put the chain on them.
I can get tilt either to the front or back by changing the links in the chain this way. Dont need no stinkin leveling bar or anything. |
#10 |
NOT a Web Wheeler
I used the valve cover bolt holes, I would have used the leveler if I was removing or installing the motor/trans/xfer case at the same time.
1983 CJ-7, 258, T177, D300, 3.54’s and 32” KM2’s Many thanks to those with contributions to my build: twoleos617, Jim1611, Yellow85CJ, kickingprop, CJnPA, Fatman, Grewel, -boom and VACJ7...oh crap, and EXPOSED too!!! Money Pit >>>http://www.jeepforum.com/forum/f8/daves-83-cj7-build-891652/ ...a jeep ensures you don't have a drinking, drug or woman problem: always dirty, broke and tired. "ACAD_Cowboy" |
#11 | |
#12 |
#13 |
I used the head bolt and the alternator bolt hole also. I would pull the engine by itself, and take the grill, and fenders off too.
83 CJ, yeah its a 5 1. Christopher Columbus did not need directions and neither do we.
#14 |
Jeep. There's Only One
I used holes on the side of the head.
. 1984 CJ-7 Renegade __________________ Restoration Thread:http://www.jeepsunlimited.com/forums/showthread.php?t=434226 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
