What is this? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > What is this?
All Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 05-10-2015, 04:35 PM   #1
JeepdaddyRC
1983 CJ5
What is this?
What is the wire with a "resister" in middle of the frame?
JeepdaddyRC is offline   Reply With Quote Quick reply to this message
Unread 05-10-2015, 04:42 PM   #2
RadioRadio
1980 CJ5
Looks more like a diode, what is it connected to?
RadioRadio | 1980 CJ-5
RadioRadio is offline   Reply With Quote Quick reply to this message
Unread 05-10-2015, 05:22 PM   #3
JeepdaddyRC
1983 CJ5
Here you go. One end coming out of loom by the CTO (disconnected by PO), the other attached to the throttle spring bracket.
Unread 05-10-2015, 06:35 PM   #4
Scardad
1981 CJ7
Looks like an early version of a flux capacitor...
Scardad is offline   Reply With Quote Quick reply to this message
Unread 05-10-2015, 08:14 PM   #5
RadioRadio
1980 CJ5
Interesting. Ok, Let me opine out loud here....maybe it can help your troubl shoot.
doesn't look stock, but I certainly am no expert.
If it is a resistor, it's way to small to be a ballast resistor. So it wouldn't be affecting ignition, directly.
If it's a diode....why would someone want to prevent reverse flow either to/from ground? And I'm assuming the spring bracket is attached to the carb, which is ultimately attached to the chassis....but it'd be a very poor place to ground anyway....
But regardless, it looks like it ties into that unplugged connector anyway, right? So it doesn't really matter, because it's not part of any circuit.
It may be an artifact from a nutter bypass? My jeep is pre-ecu era, do I have no experience with the nutter process.
Hopefully someone has better insight, sorry I couldn't be more help.
Unread 05-10-2015, 08:22 PM   #6
Monohm
If it is a diode would be a zener diode, which acts as a voltage regulator. A zener diode will prevent the voltage to be higher than its nominal value. Usually connected in parallel with the circuit's load.
Monohm is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 02:18 AM   #7
keith460
Jeep. There's Only One
keith460's Avatar
Might be part of the old Idle Relay system that went through a Diode Assembly and operated a Solenoid Vacuum.
Pink wire with tracer?
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 06:28 AM   #8
John Strenk
John Strenk's Avatar
1976 CJ5
Does this 83 have a computer originally or just the idle speed control box?
I agree with radioradio, odd, poor place for a ground.
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 11:58 AM   #9
JeepdaddyRC
1983 CJ5
John, the 83 does have the ECU. However, thanks to this great forum I completed the Nutter and Team Rush upgrade. This remains a puzzle!
Unread 05-12-2015, 04:33 PM   #10
JeepdaddyRC
1983 CJ5
Here is closer view. This is attached to an orange wire hooked to red wire with female connector that vanishes into loom by CTO. The other end is grounded at throttle return spring bracket. I'm stumped!
Unread 05-12-2015, 06:48 PM   #11
hutch1200
hutch1200's Avatar
1979 CJ7
Could it be an electronic "idle increase circuit" for raising rpms when getting thru boulders?
I have no 258 experience, just a shot in the dark.
Once a year, my CJ looks cool. St Patrick's day! Seriously, paint is my next project. And awhile ago you guys came through when I was waffling on the color & you guys threw up some Loden Green metalic. I forget who had a sweet Green Golden Eagle. Thanx guys!
hutch1200 is online now   Reply With Quote Quick reply to this message
Unread 05-12-2015, 07:45 PM   #12
John Strenk
1976 CJ5
Unless we can find the other end, I don't think we can answer this...
I don't have a schematic of an 83 with ECU but in 84, they put 3 diodes in a pack and connected it to the Solvac solenoid. Maybe in 83, they didn't use the diode pack with ECU.
Unread 05-13-2015, 03:36 AM   #13
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
It sure looks like a zener diode and my book shows one going to ground from the diode pack that ran the solvac.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 05-14-2015, 12:29 PM   #14
JeepdaddyRC
1983 CJ5
The sol-vac is long gone. Can this little diode and its ground at the carb be eliminated?
Unread 05-14-2015, 12:30 PM   #15
Mike Romain
Yes, it isn't part of the ignition, it was an ECU related part.
Mike
