what is this? - JeepForum.com
post #1 of 12 Old 04-15-2013, 07:14 PM Thread Starter
jamison
what is this?
I was doing some work on my alternator today (trying to get it to charge the batt). I'm pretty sure I got it working but found this and have no clue what it is. Any ideas? It's mounted towards the front of the passenger fender. I located the voltage regulator but it's further back. This guy only has one black or dark grey wire coming out of it.
jamison is offline
post #2 of 12 Old 04-15-2013, 09:51 PM
JeffreyCharles
1976 CJ5
That's your ignition module/computer. Called the ignition control unit in the FSM.
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #3 of 12 Old 04-16-2013, 02:05 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Well it could be either of these:
Left is the idle speed controller, right is a prestolite ignition control module.
Since it's a 77, it's probably not the idle control so I agree with JeffreyCharles and it's an unused ICM for a Prestolite Distributor.
John Strenk is online now
post #4 of 12 Old 04-16-2013, 06:44 AM Thread Starter
jamison
Thanks for the help guys. I hated to leave it just sitting there not connected. Guess that means it's coming out. One last question, I suppose. While waiting for the alternator there was and extra grey wire on the alternator itself. Other than that I had a red (I suppose to charge the battery ), a black ground and a green (to the solenoid). From what I read the grey goes to the ignition and there is a purple wire cut at about the alternator that I traced to the top of the fuse block. I also left it unhooked as my wiring is a rats nest and I just threw in a push button start to get it running. Any thoughts on the grey/purple wire?
jamison is offline
post #5 of 12 Old 04-16-2013, 07:30 AM
wellmax
Jamison,
if your jeep runs and that part is not connected, I would take it off and gently place it in a box marked:
"parts that came off the jeep and were not needed at the time"
under no reason to throw it away at this time.
someday, down the road, you may hit a big bump and the jeep stops running, because the (whatever it is, is not hooked up)
Good luck,
its about time to get the tops off our old jeeps around western KY
wellmax is offline
post #6 of 12 Old 04-16-2013, 07:30 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
purple is usually temp sending unit and usually comes from that area.....
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #7 of 12 Old 04-16-2013, 07:43 AM
frhrwa
Fish'n Fool
frhrwa's Avatar
be really really careful with that, its a TDM detonator, set to explode if the second amendment is taken away...
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #8 of 12 Old 04-16-2013, 07:55 AM
nosheep
1983 CJ7
^--- this but I was thinking, Be really careful with that its a ICM and is set to explode from the factory if you look at it wrong. During my build I broke down and bought a DUI to get rid of that POS.
nosheep is offline
post #9 of 12 Old 04-16-2013, 08:00 AM Thread Starter
jamison
Originally Posted by wellmax View Post
Jamison,
Good luck,
Definitely a good idea. I originally got the jeep when i was 16 and had no clue what I was doing. i had pulled off anything i could get two with a set of wrenches and a pocket knife. Left everything just scattered around. Thankfully, my dad was awesome enough to know i would realize my mistakes down the road and picked up the pieces and organized them in a big set of drawers with individual compartments. And now that I'm trying to get it back running again, I have had many scenarios where i think I need something and just have to go shopping in the drawers. Thanks dad!
Thanks for the heads up. I think i have a schematic of my fuse block somewhere ( from trying to wire up the push button ignition). I'll try to trace it starting from there.
jamison is offline
post #10 of 12 Old 04-16-2013, 02:19 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
According to my manual, solid purple is oil pressure sender.
Purple w/white tracer is temp sender.
Good luck,
Matt
Matt1981CJ7 is online now
post #11 of 12 Old 04-16-2013, 03:01 PM Thread Starter
jamison
Good luck,
Matt
Cool. Thanks. Which manual do you have?
jamison is offline
post #12 of 12 Old 04-16-2013, 03:03 PM
Matt1981CJ7
1981 CJ7
I have a couple, but I looked that up in my Haynes.
Matt
