Well here goes more money....... - JeepForum.com
post #1 of 26 Old 11-16-2008, 04:54 PM Thread Starter
sakisaki400
1980 CJ7
Ok so me and my friends went camping last night and brought the jeeps out. Mine did great and this was really the first time I had put it through some good mud holes. Well the last hole is known to everyone as the 50 50 whole. Seemed more like the 70 30 to me but I tried anyway. I got stuck and had to be pulled out. While I was in the mud hole all the sudden I could make the tires spin anymore. It feels like the clutch is in all the time. I can float through all the gears and nothing happens. Tried 4lo 4hi and 2wd still nothing. The jeep runs but nothing will engage. I have no clue what this could be other than its going to cost more money.
sakisaki400 is offline
post #2 of 26 Old 11-16-2008, 05:18 PM
Bard
I would go back to basics. Double check underneath for any visible leaks or breaks on driveline and tranny/t-case areas. Then start it up, make sure your clutch is working correctly with all the linkage engaged and disengaged. Next I would try to shift thru the gears with the t-case in neutral. then try with the t-case engaged in all. Go thru the fundamentals and try to eliminate any of the problematic areas and post back.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 26 Old 11-16-2008, 05:23 PM Thread Starter
sakisaki400
1980 CJ7
Yeah I tried those things. I couldnt see much through all of the mud. But I did go through all of the gears every way that I could. Also my clutch went to feeling really mushy at the very bottom and the clutch is only 3 weeks old.
post #4 of 26 Old 11-16-2008, 05:38 PM
mylittlecj5
1974 CJ5
probably got mud or a rock in the clutch
Default Jeepers Club #10
mylittlecj5 is offline
post #5 of 26 Old 11-16-2008, 07:38 PM Thread Starter
sakisaki400
1980 CJ7
how hard is that to check or should I take it to the shop?
post #6 of 26 Old 11-16-2008, 11:09 PM
rrisher
1987 YJ Wrangler
How mechanical are you...? Then the next question is do you want to spend the money to have a shop look at it for something that just may be lodged in there preventing the clutch from working?
rrisher is offline
post #7 of 26 Old 11-17-2008, 06:03 AM Thread Starter
sakisaki400
1980 CJ7
On a scale from 1-10 on how mechanical I am......probably looking at a 3 maybe 4. hahaha
post #8 of 26 Old 11-17-2008, 06:21 AM
mcmud
1983 CJ8
Are you running with the two piece axles, hub with nut?
mcmud is offline
post #9 of 26 Old 11-17-2008, 07:13 AM Thread Starter
sakisaki400
1980 CJ7
I am not sure....are you asking if I have to get out and lock the hubs? As far as I know everything is the stock set up for a 1980 4 cyl.
post #10 of 26 Old 11-17-2008, 07:28 AM
mcmud
1983 CJ8
The two piece axle is prone to spin at the hub.
Check at the center of the rear hub for a plastic dust cover over the nut which presses the hub onto the shaft. maybe time for a one piece axle mod.
mcmud is offline
post #11 of 26 Old 11-17-2008, 07:52 AM Thread Starter
sakisaki400
1980 CJ7
Sounds expensive about like everything else...haha. If that was the case wouldnt you think the front tires would turn?
post #12 of 26 Old 11-17-2008, 08:53 AM
Maxdaddy
have you checked your headlight stabalizer?
Maxdaddy is offline
post #13 of 26 Old 11-17-2008, 01:24 PM Thread Starter
sakisaki400
1980 CJ7
anymore ideas? mechanic said on the phone it could be the transfer case. anyone know how much those run?
post #14 of 26 Old 11-17-2008, 01:27 PM
j33pman
cheap to alot, depends on where you find it. Could find it on ebay or craigslist for a couple hundred
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #15 of 26 Old 11-17-2008, 06:38 PM
Jeep2003
1946 CJ2A
you could float thru the gears without engaging the clutch? and your sure its running. Sounds pretty broken. Could be anything. Nothing has to cost money unless you let it.
1967 cj-5, 1946 Willys Jeep cj-2a, 1982 911sc turbo look, 1958 impala, 1987 k5 blazer
Jeep2003 is offline
Which is the best lightbar for the money? White92 Jeep CJ Forum 12 07-16-2007 10:11 AM
Money = New Steering bdmonist Jeep CJ Forum 33 08-08-2006 01:28 PM
any money out of it TUPPERCJ7 Jeep CJ Forum 6 01-13-2005 11:23 AM
Pix of my Money pit DaveFL Jeep CJ Forum 8 07-15-2002 08:40 AM
Money? crusty Jeep CJ Forum 13 05-26-2002 05:36 PM
