Welding spring perchs to front diff to correct spring placement - JeepForum.com
post #1 of 9 Old 11-10-2011, 06:08 AM Thread Starter
Ironhorse6
1983 CJ7
PO put a spring over lift on the jeep. the rear diff is fine, they added perchs to the top but left the bottom on so i just put it back with the proper 4" springs
now to the front....they took the original perchs off
im putting on 4" lift springs and new shocks but i have to weld new perchs for it to work
im worried about getting them in the right location to have proper drive line angle. currently the pinon is angled upward giving it a neutral caster. i still have to put the tranny and transfer back in first so make sure i have good drive line angle
any lessons learned is appreciated
Ironhorse6 is offline
post #2 of 9 Old 11-10-2011, 06:46 AM
CSP
The front one on the passenger side is cast as part of the differential if it's the stock axle. It would be very difficult to remove, so check again. If it's there that's the basis for the angle for the drivers side perch. If it's gone, make the SUA perches parallel to the SOA perches.
CSP is offline
post #3 of 9 Old 11-10-2011, 06:56 AM Thread Starter
Ironhorse6
1983 CJ7
no perch on either side
i need to check caster angle i believe because the pinon is angled upward and it looks like i have neutral or negative caster. parallel wont work if thats the case....guess in need to measure angle....thanks
post #4 of 9 Old 11-10-2011, 07:04 AM
CSP
Measuring is the best bet if you don't trust the existing perches. Make sure that weight is on the axle when you do it. Put a perch in the approximate location and bolt everything together before welding. Get weight on it, set the angle and tack the perches in place before removing anything.
CSP is offline
post #5 of 9 Old 11-10-2011, 07:19 AM Thread Starter
Ironhorse6
1983 CJ7
Thanks, thats what i was thinking but needing some confirmation here
in order to get weight on it i will have to bolt the everything together..the axel to the springs with the "loose" perch underneath and check angle from there. unless there is another way to get weight on it, thats the direction i plan on going. i also have 2 and 2.5 degree shims but since im welding the perchs i think i can avoid that by getting it right the first time with perch
post #6 of 9 Old 11-10-2011, 07:21 AM
CSP
So what happened to the cast in perch (I'm assuming that this is a stock Dana 30 axle)? Did they grind it off?
CSP is offline
post #7 of 9 Old 11-10-2011, 07:24 AM
nshefbuch
1982 CJ7
Rotating the front axle will change your caster so be careful. It sucks to muscle everything in place before tacking welds but it ensures proper alignment.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #8 of 9 Old 11-10-2011, 08:00 AM Thread Starter
Ironhorse6
1983 CJ7
yes....i assume so. only thing left is rust marks
post #9 of 9 Old 11-10-2011, 09:33 AM
CSP
Watch your perch height so that the passenger and drivers side perches are the same height from the centerline of the axle tube. You'll have to raise the drivers side one higher from the tube to make up for the height of the cast diff.
CSP is offline
front spring plates with YJ spring conversion dharmabum Jeep CJ Forum 6 04-19-2011 10:46 AM
Front spring pack and rear spring pack billybooster2 Jeep CJ Forum 1 04-07-2011 09:05 PM
Welding on new spring plates & truss questions MoC Jeep CJ Forum 12 08-29-2010 01:38 PM
Spring mount to frame placement Skerr Jeep CJ Forum 6 07-02-2009 01:30 PM
has anyone used the yj leaf spring conversion for a cj and or axle over spring kits? rhino1 Jeep CJ Forum 0 08-11-2004 08:23 PM
