Welding question - exhaust pipe - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Welding question - exhaust pipe
Rubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955XHD Heavy-Duty Hood Latches for JK and TJ available at Oco
Unread 05-20-2014, 04:50 PM   #1
Kstein
I need to cut this exhaust pipe to the left of the weld in this picture. How far back inside the outer pipe (left) would you guess that the weld travels. Hope to preserve part of the expanded section. Trial and error is an option, I reckon.
TAMC85 CJ7
Still Original: Tub, Rollbar; Frame; 258 Block; T176; DANA300; Steering; DANA30; AMC20; Drive Shafts; Wheels; Tank; Altenator; Fan; Frt Bumper; Speedo; Heater Box; Spare Carrier; Seat risers
Replaced: Radiator; Valve Cover; Clutch linkage; Taillights; Frt Brake Calipers; Fuel, Tmp, and Oil Pressure Gauges; Exhaust line; Seat Belts; Paint
Mods: Mopar MPI(in progress); 4.0 Al Cylinder Head; OME YJ Suspension; MC Seats; Tub liner; 31" Tires
Kstein is offline   Reply With Quote
Unread 05-20-2014, 04:54 PM   #2
Newbjeep
1972 CJ5
You can cut tight to the weld it won't travel dont inside the pipe
Newbjeep is offline   Reply With Quote
Unread 05-20-2014, 05:03 PM   #3
Kstein
Thanks
TAMC85 CJ7
Unread 05-21-2014, 02:35 AM   #4
BagusJeep
BagusJeep's Avatar
1981 CJ7
You will have to pull out the inner pipe. If it is stuck / rusted a bit of heat and a light hammer will work it out.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote
Unread 05-21-2014, 06:50 AM   #5
bptactical
Weld metal does not "flow" into a joint like solder does, so the first post is correct.
Chop it right behind the weld.
bptactical is offline   Reply With Quote
