Welding problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Welding problems
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 11-05-2011, 09:27 PM   #1
RenoF250
Welding problems
I have my grill off trying to fix it up and paint it. It has some cracks at the bottom where the radiator mounts. I went to weld it and it just will not weld. I am using 6013 rod and it all looks like it is going every time I end up with a bead on each side and slag in the middle. It is very frustrating. Any ideas?
RenoF250 is offline   Reply With Quote
Unread 11-05-2011, 10:11 PM   #2
notforsale
1977 CJ5
Not sure whats going on there. Maybe I could help more with pictures?
1977 Jeep CJ5 Build
notforsale is offline   Reply With Quote
Unread 11-05-2011, 10:16 PM   #3
RenoF250
I will try to get some tomorrow. Not sure I want evidence of my horrific welding on the web though. This whole repair is making me wonder what the next owner of the Jeep will be saying about me when they find it.
Unread 11-05-2011, 10:20 PM   #4
Bojeepus
sounds like your got your welder turned up a little to hot, and are burning thru the sheet metel? just guessing with out picutres im not sure
Bojeepus is offline   Reply With Quote
Unread 11-05-2011, 10:49 PM   #5
jeepwhore
Trying to weld sheet metal in a continuous bead, especially with a stick welder, is fighting an uphill battle. Try using short bursts to tack the crack in several spots and as mentioned, turn the machine down.
'84 CJ-7: 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, Yukon 1 pc axles, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rear aussie locker, twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is online now   Reply With Quote
Unread 11-05-2011, 10:58 PM   #6
Sgt_Utz
Dude stick welding sheet metal? You need very low voltage, amps, .023 wire or tig... With sheet metal you're not concerned about penetration...
As was said above, stick welding sheet metal is an uphill battle!
[SIZE="5"]Does your gas tank overflow at the pump? [B][URL="http://www.jeepforum.com/forum/f9/have-fuel-spill-problems-like-many-us-submit-complaint-force-recall-974337/"]SUBMIT COMPLAINT HERE![/URL][/B][/SIZE]
[SIZE="5"][B][URL="http://www.jeepforum.com/forum/f9/05-06-gas-overflow-fix-1335243/"]A permanent fix has been found for the gas overflow problem![/URL][/B][/SIZE]
[QUOTE=IPA;11608009]"See, I told you so." - Thomas Jefferson, 2011[/QUOTE]
Sgt_Utz is offline   Reply With Quote
Unread 11-06-2011, 12:33 AM   #7
RenoF250
I welded the body on the drivers side mount just fine for some reason the steel in the grill is giving me problems. I am not trying long beads, just short tacks, same result. I don't have a MIG and I tried doing it TIG and could not get the two to flow together but I am no good at TIG. I was down at 22A and have gone up to 38A no difference. I was running AC, I will try DC tomorrow and take pics.
Unread 11-06-2011, 01:00 AM   #8
Bojeepus
stick still isn't the ideal but it can work. im just wondering did you clean the crack up at all, get any and all rust out?
Unread 11-06-2011, 02:42 AM   #9
mashunitjeep
1972 CJ5
my question is are u trying to weld aluminium? just curious
Im not related to kate middleton
mashunitjeep is offline   Reply With Quote
Unread 11-06-2011, 03:31 AM   #10
Bojeepus
thats a good question, but wouldn't aluminium break first instead of cracking?
Unread 11-06-2011, 04:25 AM   #11
mashunitjeep
1972 CJ5
well the reason i ask cause some those brackets are aluminum and it wont mend it would just get hot and melt lol
Unread 11-06-2011, 05:04 AM   #12
243
243's Avatar
1983 CJ7
Maybe the OP only has a stick welder at his shop.
I have limited skills stick welding but many principles of welding apply whenever you weld with any machine.
1. Turn the machine down low.
2. Fit-up must be *tight* and no gap is best.
3. If you can back up the joint, a piece of 1/4" or thicker copper or aluminum clamped to the back of the joint minimizes burn-thru.
4. Short tacks.
Good luck!
1983 CJ7
258/T177/D300 3.54 32" BFG KM2
THE BEGINNING:
http://www.jeepforum.com/forum/f8/da...2/#post8211912
In the 80's we had Reagan, Bob Hope, and Johnny Cash
Now we have Obama, no Hope, and no Cash
243 is offline   Reply With Quote
Unread 11-06-2011, 05:05 AM   #13
gmakra
Welding sheet metal with stick is a real PIA but you could try flattening a small section of copper pipe and using that as a backing behind the weld. Copper has a high rate of thermal conductivity and will not stick to the metal.
gmakra is offline   Reply With Quote
Unread 11-06-2011, 06:18 AM   #14
Area.3.Fiftyone
A couple of things:
Stick welding is not a good choice for sheet metal. Use a MIG setup.
Clean it up so that everything is shiny.
There must be no gaps between the two pieces of metal.
Use DC current - not AC
If you don't have a MIG, take it to someone that does and throw them a couple of bucks to lay a bead for you. I would not waste my time burning it all up with a stick welder.
If you are trying to fill in a crack with a gap, take a piece of copper pipe, cut it long ways and flatten it out. Lay the copper underneath between the gap and clamp it on both sides and use it as a backer. The new weld will not stick to the copper and will help prevent burn through.
It's hard to see what you are trying to do without pictures.
[COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Black"][URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #666[/COLOR][/URL][/FONT][/SIZE][/COLOR][/COLOR]
[/CENTER]
79' CJ7
82' CJ8
94' YJ
96' ZJ
[i]Diagonally parked in a parallel universe........[/I]
Area.3.Fiftyone is offline   Reply With Quote
Unread 11-06-2011, 06:29 AM   #15
mashunitjeep
1972 CJ5
x2 on that
