Welding a Header???? - JeepForum.com
post #1 of 5 Old 01-27-2010, 02:43 PM Thread Starter
Daves77CJ7
1977 CJ7
Ok guys; I need your opinion here. I have a set of Hedman dual port Hedders on my CJ. Unfortunately I have one tube that is cracked about 1" away from the mounting flange (by the engine). Has anyone ever tried to weld one of these tubes before? Can it be done so that it can actually hold up? Or should I just scrap the headers and buy a new single port? I hated the stock exhaust manifold because it always leaked at the collector. Not to mention I have an Offenhauser aluminum intake and don't really want to mount it up with a stock exhaust manifold.
Many thanks.
Dave
Daves77CJ7 is offline
post #2 of 5 Old 01-27-2010, 02:48 PM
BioTex
1979 CJ7
Weld away. TIG works the best. I have welded them many times.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3 of 5 Old 01-27-2010, 04:37 PM
petey156
yep go for it!! i use .023 mig wire, worked great!
petey156 is offline
post #4 of 5 Old 01-27-2010, 09:02 PM Thread Starter
Daves77CJ7
1977 CJ7
OK. Looks like I will weld them up. Do you guys recommend any special paint after I weld them? Something that may help keep any rust off? What about that header tape? I have never seen or used it before.
Thanks
Dave
post #5 of 5 Old 01-28-2010, 12:00 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Header tape has had a reputation for causing rust. Keeps the heat and moisture in, or something like that..
Run them daily, won't rust that bad
Rick
Cutlass327 is offline
Welding want-a-be JonnyLaw Jeep CJ Forum 12 02-21-2009 09:07 AM
Welding Equiptment? CJman77 Jeep CJ Forum 5 05-19-2008 08:10 AM
Frame Welding ??? Dandude80cj7 Jeep CJ Forum 4 09-08-2005 09:41 PM
welding amc 20 wilf Jeep CJ Forum 6 01-05-2005 07:00 PM
welding on the frame!! muddin84cj7 Jeep CJ Forum 5 12-04-2003 10:33 AM
