WELDING AXLE TUBES - JeepForum.com
post #1 of 5 Old 02-14-2002, 05:09 PM Thread Starter
2cjs
2cjs's Avatar
Cool WELDING AXLE TUBES
Ive been reading that if u put one piece axles in a model 20 rear that u should weld the tubes.I have no problems with welding the tubes.My quesions are (1)if i dont they will break right?.(2)can i weld them without taking my rear apart?.(3)should the truss be on top or bottom?Just for info im runnin a 304 and plan to install 4.10 gears in the rear so i will probably take it apart anyway.I have moser one piece axles in the rear.One more question i am going to put 35 inch tires on her and ive been reading that 32 and 33 inch tires are the majority for rock crawling.I have a 4 inch suspention lift on her will i have tire rub?I dont mind a body lift if i need one.kenny
83 cj-7 258c.i., 727auto, d300, d44 front, d60 rear
92'yj 4.3(roller) tbi chevy,700r4 ,soa, 35-12.50-15 maxxis bighorns
89'yj wife's jeep 4.2l stock ,2"bl ,31-10.50-15 bfg mud terrains
work smarter not harder
2cjs is offline
post #2 of 5 Old 02-14-2002, 08:39 PM
rivertrout10
rivertrout10's Avatar
Post
I am not so sure that you HAVE to weld your axle tubes. I say this because I too have the AMC 20 rearend and have run Moser one piece axles for over two years without any breakage - also have a LockRite locker. A buddy of mine has the same set-up and has had his for four years or more - no weld and no breakage. I dont think welding is a bad idea and would certainly only be a benefit. Just thought I would share my experience without welds - take it for what it is worth.
As far as the tire size - I have the RE 4.5 lift on mine with 33's and have plenty of room for 35's. My only caution is depending on what kind of lift you have you may be able to put 35's on now but in a year or so you will have sag and your 35's may rub at that point. Suggest you do the re-gear before running 35's however - many folks complain after going with 35's without correct gearing.
Good Luck,
Derek
Jeep - its a job - not an adventure
rivertrout10 is offline
post #3 of 5 Old 02-15-2002, 08:11 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Man that is one good look'n truss!
I hope that's one your ride, Mr. Bill.
I very much envy you. Spent three weeks in CO Springs, I though I would be moving there, but I took a different job. The 4x4 shops out there blow away the places in the Northeast, even though there are a couple of really good ones here.
Hope to drive my CJ out there one day for about a month of wheeling in CO, Utah, etc.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #4 of 5 Old 02-15-2002, 05:19 PM Thread Starter
2cjs
2cjs's Avatar
Thumbs up
Hey mr bill that is one hell of a truss.beautiful beads i might add.Hey bill is that kindorf u used?by the way how many seconds do u suggest on the welding process?How did u mount the brake lines?they split on the tube and mount to the top of the tube u know center of top.I love that truss ,if that was kindorf u used thats cool because i can get that from work.By the way if thats kindorf was it 1 1/4" or 1 1/2 "kindorf? thanks kenny
2cjs is offline
post #5 of 5 Old 02-16-2002, 07:32 PM
junger
Post
If I remember correctly, they told me in my welding class to be careful of welding when you have bearings. But, if you put your ground clamp between the weld and the bearings you should be ok. Personally, though, you really don't need to weld the axle tubes in the first place... several people use the 1piece axles with that mod. If you do it, throw in those 4.10 gears at the same time.
Good Luck.
-Josh
junger is offline
Welding Axle Tubes Hybrid Jeep Jeep CJ Forum 27 04-08-2009 08:06 PM
Welding AMC 20 Tubes kstopp Jeep CJ Forum 6 11-27-2008 06:45 AM
Cutting / re welding axle tubes? SmichaelR22 Jeep CJ Forum 13 01-27-2007 08:51 PM
Welding Amc 20 Axle Tubes jeepping Jeep CJ Forum 9 05-06-2006 08:16 PM
Welding AMC 20 tubes..Who has? cjthor Jeep CJ Forum 8 10-28-2004 12:47 AM
