Weld on replacement parts? - JeepForum.com
post #1 of 13 Old 02-15-2008, 12:09 PM Thread Starter
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Hi, I'm just getting back into jeeping after about 12 yrs (finally divored so she can't complain about it...(-: ). Just bought a 1980 CJ7. Was wondering if anyone had used the weld on replacement body parts? Were they hard to do, cut out old or overlay etc.
Thanks,
Rick
SlikRic is offline
post #2 of 13 Old 02-15-2008, 12:50 PM
ragincajunATL
ragincajunATL's Avatar
Can you weld?
that would be the hardest part!
Welcome BACK.
1980 CJ 7 yeah its Blue
ragincajunATL is offline
post #3 of 13 Old 02-15-2008, 01:00 PM
USMCredneck
1979 CJ5
I haven't done any yet, but I have several panels waiting for me when I get to work on my 5 again next weekend. So far it looks like the hardest part will be actually welding them on, like cajun said. They are pretty thin, 19-20ga depending on who you get them from. Make sure your thin metal welding skills are up to par.
79 CJ5. 258, T-18A, D20. 33s
08 Dodge Ram 3500 DRW DD/tow rig
USMCredneck is offline
post #4 of 13 Old 02-15-2008, 01:40 PM
GPER
1979 CJ7
Don't try to run a bead, do a bunch of tack welds. Jumping all over the panel to keep it from getting too hot.
GPER is offline
post #5 of 13 Old 02-15-2008, 03:39 PM
roundlitefan
roundlitefan's Avatar
Saw a really cool presentation by a professional sheet metal welder/car restorer a few years ago.
He does HIGH dollar restores on old cars (mostly rarer MG's) for a living, and had a pretty cool technique for welding in replacement panels.
He tacks the panel on one end, and sets a widening gap along the length of the panel. He supports the far end of the panel on something then.
Basically, he starts his stitch welds on one side, and just keeps going, using the welded part like a hinge.
The welding pulls the metal up into place by the time he has reached the far end of the panel.
Basically, what I am trying to say is this. He starts with the panel not aligned properly, and lets the welding pull it into place, so he has no waves or heat distortion in the panel when he is done.
Not necessarily applicable on flat Jeep panels, but just thought it was pretty cool.
roundlitefan is offline
post #6 of 13 Old 02-15-2008, 04:40 PM Thread Starter
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I love this site
Guys, thanks for the info! I'm doing the cut out of rust and protection application this weekend. Hopefully will be able to get the panels ordered in a few weeks. I,m looking at JC Whitney. 19 guage steal, anyone have a better site? Thanks again for the help. yOU GUYS ARE great!!!!!!
Rick
SlikRic is offline
post #7 of 13 Old 02-15-2008, 05:53 PM Thread Starter
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I love this site
Rick
SlikRic is offline
post #8 of 13 Old 02-15-2008, 06:10 PM Thread Starter
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
ragincajunATL- It's been about 12 yr's, byt yes I know how.
USMCredneck:Can you let me know hot it goes?
I have 3 boys and just don't the time or the money to an off-frame-rebuild right now, but would like to get it as close as possible as cheap as possible. thanks. Rick
SlikRic is offline
post #9 of 13 Old 02-15-2008, 08:05 PM
roundlitefan
Alot of the places that rust are flat, I would think if you want to use thicker panels, you could just go buy a few sheets of mild steel at your local weld shop and cut patches to fit.
Nothing too crazy on a Jeep as far as contours or weird angles, so just get a piece of flat stock and two c-clamps, and use your workbench as a brake.
Probably save a lot of money that way too.
post #10 of 13 Old 02-16-2008, 06:57 AM
ragincajunATL
Rick
when I flipped my heep over I had a stop sign and speed limit sign as my floor
.........done by the PO. Although since it was already there, I have used it for other projects
post #11 of 13 Old 02-16-2008, 11:05 AM
muddmonky
i replaced the frount floor pan area (just where your feet go)
and both wheel wells.
all the parts are cj/yj so everything is a little off. i had to shape some areas of the sheets with a hammer and a flat serface (the drive way) to make them fit better but they all went in.
parts needed
body pannels
welder
hammer
lots of time
and 1-2 six packs
muddmonky is offline
post #12 of 13 Old 02-16-2008, 02:52 PM Thread Starter
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Thanks Muddmonky, that makes feel a little more confident. I need both floor pans and the rear wheel covers done.
Toooooo much rust to patch. Can I post pics here?
SlikRic is offline
post #13 of 13 Old 02-16-2008, 11:33 PM
USMCredneck
1979 CJ5
I'll definitely let you know how well it all goes together. I went with Quadratec when I bought my panels because I had to buy quite a few and they are a little cheaper than JC Whitney. Your rear inner wheel wells are 60.00 on JC Whitney and only 40.00 from Qtec.
You can post the links to pics hosted on another site, You got to have 50+ posts before you can post just the pics here though.
Steering parts replacement advice atomicflatulenc Jeep CJ Forum 3 01-13-2010 08:10 AM
Warn hub replacement parts?? Johnnylaw Jeep CJ Forum 1 02-24-2009 05:09 PM
Intermittent Wipers - Replacement Parts Scrambler82 Jeep CJ Forum 9 05-19-2008 09:14 AM
Replacement CJ parts? yucatanstan Jeep CJ Forum 11 05-06-2007 06:09 AM
Replacement parts quality ? killah Jeep CJ Forum 4 03-25-2005 02:00 AM
