wedges or shims - Page 2 - JeepForum.com
post #16 of 19 Old 11-26-2011, 02:58 PM
foggybottombob
If one side is really half a degree more than the other (don't know how this could happen unless the inner knuckles were removed and turned) even if you shim the axle to have say 5 degrees on one side and 5.5 degrees on the other, the steering will pull to the side with the most positive caster on a flat road. Half a degree difference is enough to make the steering pull to one side. You can add half a degree of caster to one side with an offset ball joint from moog. I had to do this on an XJ once.
But, I still find it hard to believe that your caster is that far off from one side to the other. You can not correct the difference with shims. When you rotate your axle with shims both knuckles will be turned by the same amount.
foggybottombob is offline
post #17 of 19 Old 10-16-2013, 08:13 PM
dirtyb
1981 CJ8
Centering Pin
I'm fixin' to do the same job. If I buy new centering pins, do I need to get longer ones?
dirtyb is offline
post #18 of 19 Old 10-17-2013, 12:00 AM
Spieg8
1984 CJ8
Yes, if you install shims, your old centering pins will need to be replaced. Usually when you buy them, they are oversized and need to cut off the excess length once they have been tightened down. As stated earlier, it's advisable to get steel shims that are designed to be bolted to the spring pack (they last longer and are more secure).
Spieg8 is online now
post #19 of 19 Old 10-17-2013, 05:52 AM
gmakra
If you take your spring pack apart its a good idea to remove the rust between the leaves and apply a coat of never seize in between the springs. You will be amazed at how it softens the ride.
gmakra is offline
Phelp.lans for DIY Sound Wedges? elks96 Jeep CJ Forum 2 05-17-2011 10:27 AM
VDP wedges or Mod-Pod wedges? kakai81 Jeep CJ Forum 2 04-24-2011 02:38 AM
VDP 6x9 sound wedges on 79 CJ7 gtrpup2 Jeep CJ Forum 14 08-17-2010 09:11 AM
sound wedges? drunkenrich Jeep CJ Forum 3 04-06-2008 07:58 PM
wedges-which way up? duitinmud Jeep CJ Forum 1 11-21-2002 03:39 PM
