weber tuning problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > weber tuning problem
Steering and more from Ruffstuff!Rough Country Deals at JeepHut.comThe Ruffstuff 14 Bolt Complete Swap Kit!
Unread 12-02-2007, 01:08 PM   #1
billyroy
1977 CJ5
Hi, I have the 258 with a 79 cj and it runs semi rough. I put on a fuel regulator and then i turn in the idle mixture screw all the way in (lightly) and it doesn't affect the way it runs. Any thoughts on that please? Thank you, Bill
billyroy is offline   Reply With Quote
Unread 12-02-2007, 01:43 PM   #2
RobP
have the same issues
No regulator (one ordered from 4wd.com) runs rough.
Keep me posted.....I do have the Weber directions if you'd like me to fax them to you. I haven't gotten that far yet.
RobP is offline   Reply With Quote
Unread 12-02-2007, 06:15 PM   #3
Mr.Crowley
1980 CJ7
how many turns in on the idle speed screw are ya?If i remember corectly if you have the idle turned in to much you drawl off the secondary circut and the idle mix screw will have no function..I forget who on here told me last year but maybe they will pop in..It is true..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Unread 12-03-2007, 09:08 AM   #4
JoonHoss
2011 JK Wrangler
Start here:
http://69.0.202.131/html/Tech/Table_of_contents.htm
also, what did you set your FPR at?
Hoss
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
JoonHoss is online now   Reply With Quote
Unread 12-03-2007, 05:43 PM   #5
billyroy
1977 CJ5
weber carb
Thanks for the input, I set the regulator at 3 which is recommended and I have the carb tuning for it already thank you. I will try to get what Mr Crowley suggested and see if that works.I will then repost if that helps. Thank alot, Bill
Unread 12-03-2007, 07:58 PM   #6
twmattox
The two screws that control mixture for low end on the Weber is the idle mixture screw and the speed screw. If your idle mixture screw is too far in, many people compensate by turning the speed screw in (opening up the secondary circuit and allowing the carb to run too rich). Follow your instructions to the letter (it will indicate how many turns in for the speed screw {usually no more than 1.5} and turns out for the mixture screw {usually no more than 2}). Then tune to the lean best setting...
twmattox is offline   Reply With Quote
