weber tuning 32/36 & engine tuning help - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > weber tuning 32/36 & engine tuning help
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 10-13-2011, 04:18 PM   #31
JeepScrambler
1985 CJ8
Sounds like you are doing it right, your timing might just be that far off that it isn't showing up. It might be just slightly ATDC(retarded) or quite a bit BTDC(advanced). If I had to take a guess, I would say your engine is slightly ATDC. You could try increasing the RPM with the timing light hooked up and see if the timing mark begins to show up; if I remember correctly you can turn the distributor clockwise to retard the timing, counter-clockwise to advance.
1985 CJ8, '85 CJ8, '85 CJ7, '84 CJ7, '84 CJ8, 2-'84 CJ8 AK Postal Scramblers, '82 CJ8, '82 CJ8, '82 CJ8, '53 CJ3A
'02 Dodge Ram 2500 4x4 Cummins HO 6 spd
'06 Grand Cherokee "Overland"
JeepScrambler is offline   Reply With Quote
Unread 10-13-2011, 04:37 PM   #32
mcmud
1983 CJ8
An image indicating (yellow) those positions that JeepScrambler is referring to that are near impossible to see the mark.
mcmud is offline   Reply With Quote
Unread 10-14-2011, 08:47 AM   #33
esearscj7
1983 CJ7
Is your timing light the kind that has timing advance knob on the back? If so, make sure that knob is turned to 0. Ask me how I know. :-)
esearscj7 is offline   Reply With Quote
Unread 10-14-2011, 08:55 AM   #34
Matt1981CJ7
Lifetime CJ User
Matt1981CJ7's Avatar
1981 CJ7
Also, make sure your vacuum advance is disconnected when you check timing.
Since you are running s-port vacuum, and it's incorrectly showing 10" at idle, you are probably pulling advance at idle which would put the timing mark out of view.
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread 10-14-2011, 09:23 AM   #35
gingermesiah
1982 CJ8
Matt
it's disconnected with the vacuum gauge attached at s port, was just going to leave it there until I get the vacuum is dialed in.
gingermesiah is offline   Reply With Quote
Unread 10-14-2011, 09:25 AM   #36
gingermesiah
1982 CJ8
I have the cheapest one harbor freight has. no knobs no adjustmens, just a trigger and three wires.
Unread 10-14-2011, 09:26 AM   #37
gingermesiah
1982 CJ8
I think thats a great idea. just need a second person to help out. that means a beer run. jk
Unread 10-14-2011, 09:34 AM   #38
gingermesiah
1982 CJ8
Ginger,
Yes, that is the s-port, but you shouldn't be reading 10" at idle. It should read 0" at idle and then climb with RPMs. I suspect your out-of-whack carb settings are causing this.
Your manifold pressure isn't bad, though I'd prefer to see it around 16-18" at idle.
Post a picture of your plugs, if you can.
Matt
I'll post the pic as soon as I get home. wires were all in the right location. plugs were all sooty black (probably because of my rich tuning) plugs have only been in a few months, mostly with the jeep sitting unused.
Replaced all the plugs with autolite platinum, changed the oil (what oil do you jeepers recommend?), oil filter, fuel filter "just in case". and double checked for spark on the first three cyliners (then I shocked myself and lost motivation). My spark is orange in color... shouldn't it be blue/white? Does this mean I have electical issues?
emissions , idle issue , weber carb
