Weber Set-Up and Tune Discussion - Page 4 - JeepForum.com
 3Likes
post #46 of 1100 Old 10-09-2010, 09:41 AM
outsider2010
I thought Swatson 454 wanted this to be a set up/tunning thread!, Are we going to jump to main circuit soon?
Jorge.
outsider2010 is offline
post #47 of 1100 Old 10-09-2010, 12:03 PM Thread Starter
swatson454
1983 CJ7
Jorge.
Sorry guys, I've been frying other fish and burning other bridges lately. Sure, whatever you guys want to jump into next.
Of course, we haven't touched on the effects of the fuel level being too high or too low in the bowl yet. That should probably come before getting into the mains, IMHO.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #48 of 1100 Old 10-10-2010, 03:42 PM
BigOrange90YJ
Originally Posted by rclark678 View Post
So I should ditch the 32/36 in favor of a bigger Weber? I am just asking, I have the 32/36 and it seems to have hesitation when I gas it. However I will add I have not done anything to the carb. to try and adjust other than, add a regulator. I do like the plug and play option if there is one.
The Weber 32/36 will work perfectly fine when you tune it. I used to have the hesitation problem but once I took the time and learned how to tune my carburetor I couldn't be happier with how it runs. If you would like to learn to tune your 32/36 just ask, we'll point you in the right direction.
Currently Jeepless, if you get too frustrated with yours I'll take it off your hands.
BigOrange90YJ is offline
post #49 of 1100 Old 10-10-2010, 03:49 PM
ozzieb
1977 CJ5
Originally Posted by uptillnow View Post
How did your carb work out? What happened? This was a long time ago you had some linkage problems, then a starting or quiting problem? What happened?
UPTILLNOW
It turned out that my ignition Mod was bad. Causing the issue. But it works great now. swatson and Mcmud helped with the linkage issues and tuning.
ozzieb is offline
post #50 of 1100 Old 10-11-2010, 10:45 AM
uptillnow
uptillnow's Avatar
Originally Posted by cj7jeep View Post
i have a question. i have a weber 32. its running so rich. black smoke come outs when you start it and a small mixture of water and oil. the engine is very strong.i just had the valve cover gasket replaced and it had some sludge on the valves.i'm using rotella and wix filters and have changed it twice and the oil is still dirty looking after driving 300 miles.now the past week after driving the car for a few miles and coasting at low speeds the car will cut off for a second and start right back up and not due it again. its happened 3 times in a week.any help on what i need to do appreciated
I have tuned a few 32/36DGEV on the Jeep. Most (95%) of the time the rich appearance is due to the throttle plate being opened too far, more than 1 1/2 turns in and reading vacuum at the "S" port, or the vacuum advance ported vacuum source. This throttle plate is then exposining the enrichening holes at idle brings in allot of fuel at idle that doesn't burn clean and soots up your plugs, exhaust etc.
I would look at your choke plate to insure it is open as previously stated and check your initial carburetor settings. Do you know how far in your speed screw is set? Do you know if you are reading any vacuum at the ported "S" vacuum source? Where do you find the "LEAN Best idle" with your mixture screw? Wher have you set your inital timing? Let us know, there are some people here who know the intricact details of how the Weber works that will be more than happy to help.
UPTILLNOW
uptillnow is online now
post #51 of 1100 Old 10-11-2010, 03:33 PM
DrivinCat
Weber 34
I have the Weber 34 DGEC and discovered that all of the inner walls of the float bowl had become "blistered" (for lack of better word) causing a thin, cracked layer of metal to "bubble" out away from the wall and interfere with the float. This caused all kinds of strange problems as you can imagine. Not starting; starting and then dieing immediately; poor running; stalling on hills; flooding...etc, etc. I chipped the bubbled and blistered metal out, allowing room for the float to...float, and she runs like a champ now.
My problem may be unique and/or confined to the foreign manufactured Weber carbs but I felt it needed addressed in case it helps other Jeepers.
There's also a well researched write up on the Weber 34 running rich and the proper jets to use here:
http://www.jeepforum.com/forum/f8/we...-258-a-631105/
DrivinCat is offline
post #52 of 1100 Old 10-11-2010, 03:49 PM
uptillnow
uptillnow's Avatar
How old is your carburetor? I'm sure Solex will warranty a real defect. Ussually this is the "tinning" or sacraficial coating on the metal for corrosion control. Whith the Ethyinol fuels, I am sure we will start seeing this in many areas of the fuel delivery systems. See if you can get it exchanged through the Solex/Weber dudes.
post #53 of 1100 Old 10-11-2010, 05:42 PM Thread Starter
swatson454
1983 CJ7
Shawn
post #54 of 1100 Old 10-11-2010, 07:08 PM
BigOrange90YJ
Originally Posted by swatson454 View Post
Shawn
id like to second that
post #55 of 1100 Old 10-11-2010, 07:16 PM
monkeyhouse
good to see ya around big orange, and I gotta agree with ya on that link being a big no no!
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #56 of 1100 Old 10-12-2010, 10:37 AM
DrivinCat
Sorry about the link, new here. Why is it a big no, no? 1. No to posting links? 2. The link doesn't work? 3. You disagree with the info in the link? Hopefully no 2...
This is correct link:
http://www.jeepforum.com/forum/f8/we...37/index4.html
Helped me out with jet size, worked great.
Shawn: is that Zak Wild, BLS 1919 Eternal?
Just shoot me if I did something wrong again...
post #57 of 1100 Old 10-12-2010, 10:41 AM
uptillnow
uptillnow's Avatar
Ohh yeaa... Who wants to tackle this one?
post #58 of 1100 Old 10-12-2010, 10:42 AM Thread Starter
swatson454
1983 CJ7
Nice job on the avatar! Seems pretty fitting with my cousin doing his third tour in Afganistan. And please, for the love of God, from one BLS fan to another, stop linking that propaganda to this thread! Please!
Shawn
post #59 of 1100 Old 10-12-2010, 12:25 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Shawn
Either I had a brain fart or doesn't this link us back to this thread?? I think I just spent 20 min rereading this whole thread...
John Strenk is offline
post #60 of 1100 Old 10-12-2010, 12:32 PM
uptillnow
uptillnow's Avatar
I think these links got confused along the way...
I beleive this is the link he is refering too.
Weber Operation Discussion John Strenk Jeep CJ Forum 7 03-09-2010 03:54 AM
WEBER 34 DGEC Carb TOO RICH??, Jets & Tune for Jeep 4.2 / 258 Fjguercio Jeep CJ Forum 55 05-13-2009 01:14 PM
CJ Tech CD discussion, JeepHammer Jeep CJ Forum 11 09-29-2008 07:43 AM
Who is the Weber Tune Guru? b.d.d. Jeep CJ Forum 4 07-26-2008 04:41 PM
Backfire and weber tune help rb85cj7-82cj8 Jeep CJ Forum 4 03-02-2007 08:58 PM
