Weber Set-Up and Tune Discussion - Page 39 - JeepForum.com
 4Likes
post #571 of 1148 Old 10-16-2013, 12:26 PM
Hacken
1987 YJ Wrangler
Uptilnow,
I have zero vac at s with the speed screw at one and a quarter any more than that it starts to move the needle on my vac guage. Mix screw is 1 7/8 out from close. As far as timing goes i have been around the world trying to get rid of the dead spot. Currently im at 8 with vac plugged. Ive been up to 16 and all the way down to zero. Also i dont hear much mention about redlines instructions that say set at 12* btdc and leave advance unhooked. Any reason for that?
As far as my primary idle im not sure i have not changed any and its a k551-ge through carbs unlimited. Is 75 stock so to speak?
Hacken is offline
post #572 of 1148 Old 10-16-2013, 12:34 PM
uptillnow
uptillnow's Avatar
Originally Posted by swatson454 View Post
The test I'm waiting for is a CDI vs a stealth HEI with an aftermarket module. I find that pretty interesting.
Shawn
Shawn,
Not sure what you mean.
A massive haza gauza Multi Spark with a 135mJ coil compared to "an aftermarket module" (?).
I must need some more coffee... This is what I had and was better than the Duracrap.
Let me know where I went dumb here..
UPTILLNOW
uptillnow is online now
post #573 of 1148 Old 10-16-2013, 12:48 PM
uptillnow
uptillnow's Avatar
Originally Posted by Hacken View Post
Uptilnow,
Hey Hack,
Yes, my experience has been slightly less than one and a half turns in before the needle moves on the vacuum gauge.
A check would be to loosen the nut on the primary throttle shaft one turn out, tap tap tap on that throttle shaft and tighten that nut FINGER tight, as tight as you can with your fingers, then one or two flats on that nut tighter.
Re check your turns in, with ZERO vacuum and I would guess that it should be closer to the 1 1/2 turns in on that speed screw. (whew)
Then find your "Lean Best Idle" where ever you wind up, but looking for 2 turns out with the mixture screw.
The initial timing with stock type ignition is 12* (ish). "S" ported vacuum.
The initial timing with manifold vacuum would be around 8*
Try this out and we will see if there is any improvement.
UPTILLNOW
post #574 of 1148 Old 10-16-2013, 02:45 PM
Hacken
1987 YJ Wrangler
Thanks for all the info thus far. I appreciate everyone replying so quickly. Ill check that throttle nut as soon as i get a chance and get back to you.
Hacken is offline
post #575 of 1148 Old 10-16-2013, 03:27 PM
DoubleDown
1983 CJ7
Does anyone have a part number for a pre-computer controlled distributor ?
I Nuttered my '83 and would like to use said distributor, but at autozone the part number is the same no matter which year CJ7 you type in.
DoubleDown is offline
post #576 of 1148 Old 10-16-2013, 03:39 PM
uptillnow
uptillnow's Avatar
1981 and older 258 4.2
http://www.jeepforum.com/forum/f8/we...93/index2.html
post #16
Matt say's
NAPA sells them. Be sure you can see the correct advance slot labels thru the little peep hole in the top of the dizzy.
My NAPA had to pull 3 of them before we found one with the correct. head.
post #577 of 1148 Old 10-17-2013, 06:55 PM
Hacken
1987 YJ Wrangler
Hack,
If you are using the original computer-controlled dizzy, your dead spot under load may be caused by too little centrifugal advance. Those dizzys only had about 8 degrees of centrifugal.
A pre-computer Motorcraft dizzy (1981 or older) will give you the option of running up to 18 degrees of centrifugal, and will wake your old engine right up.
My dizzy has a number two through the window. Does that mean i only have 2 degrees of centrifugal advance? I ask because i would hate to spend $60 for a jet kit if the Dizzy is the problem. the jeep idles very smooth, a little slow, but smooth. Which leads me to the question, after the lean best idle is determined, and everything is running great, is it ok to bump your idle up with the speed screw? Meaning that i would be pulling a little vacuum at the "S" port.
Hacken is offline
post #578 of 1148 Old 10-17-2013, 07:25 PM Thread Starter
swatson454
1983 CJ7
Hacken,
I think I'd cool my jets on the kit (get it?... ok, lame) It sounds like you have a good tune on the carb. I'd jump on the ignition curve at this point. Those factory curves are so terrible, it's worth doing anyways because there's no downside.
If you still have the flat spot and you're sporting a 75 idle jet, the float is no more than 18mm and you're not running a cheap regulator, I'll send you my F-6 emulsion tubes to try.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #579 of 1148 Old 10-17-2013, 10:12 PM
Hacken
1987 YJ Wrangler
Shawn,
Sounds good ill try to pick up a dizzy this weekend and see what happens.
Hacken is offline
post #580 of 1148 Old 10-18-2013, 05:25 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Here's the advance head you are looking for. Notice it has a 13* slot and a 18* slot. I ran my 258 on the 18* side.
Good luck,
Matt
Matt1981CJ7 is offline
post #581 of 1148 Old 10-18-2013, 11:49 AM
uptillnow
uptillnow's Avatar
Hey Hacken,
You have allot of information coming your way right now.
My suggestion was to just check out your carb set-up. 1/2 turns in, ZERO vacuum at idle, mixture screws "lean best idle" around 2 turns out and enough initial timing for it to set-up the carb.
Then you will probably need a dizzy as Matt has diagramed.
If you bump up the idle by turning in the speed screw more than 1 1/2 turns in, and you pull vacuum at idle from the "S" port, the enriching holes will be exposed and the throttle plate will not come down enough to stop the fuel from siphoning into the engine. This can not be good. Wash cylinders, dilute the oil with fuel, plus you will develop a stumble on acceleration.
I do not recommend anyone with "any Weber" real or a clone, to have the throttle plates opened into the enriching holes. This can not be good.
UPTILLNOW
post #582 of 1148 Old 10-18-2013, 10:24 PM
Hacken
1987 YJ Wrangler
update,
I found a new dizzy and installed it. set timing re did lean best idle rechecked timing and after that i still have the dead spot. it feels to me like when the second barrel is opening. so i guess im going to order the jet kit unless someone has a better idea.
quick word on the old distributor the markings on the advance plate were 10r and 15r where do you think that came from?
Hacken is offline
post #583 of 1148 Old 10-23-2013, 03:09 PM
Nebulas
1981 CJ5
32/36 on a 4cyl 151
Pierce Manifolds offers a complete Weber 'how to' tune up DVD for $12.oo and are a GREAT help!! My parts are on the way!!
Nebulas is offline
post #584 of 1148 Old 10-24-2013, 06:06 PM
Nebulas
1981 CJ5
see above
Nebulas is offline
post #585 of 1148 Old 10-25-2013, 11:03 PM
Hacken
1987 YJ Wrangler
Gentlemen,
Here is where im at. i have gone over everything and i cant figure out my dead spot. so i got the jet kit in and now i need to know where to go from here.
some info on my current set up. which should be stock.
primary idle - 75
secondary idle - 60
primary main - 145
secondary main - 145
primary A/C - 170
secondary A/C - 160
single pump - 50
I tried the 80 primary idle jet so far and it seemed to get my idle speed up to 750. however im only 1 5/8 turns out on the mixture screw so that tells me i should go back down to the 75 jet correct?
i also tried the 65 secondary jet and the dead spot got worse. I have checked the float and i think its good it measured 17 to 18 mm at the top of the float on the end closest to the air horns. 2mm of needle travel. so where should i go from here do you think my problem is the main jets or the A/C jets? At this point im not sure if the dead spot is because its too rich or too lean. any ideas would be greatly appreciated.
Thank you
Hacken
Hacken is offline
Weber Operation Discussion John Strenk Jeep CJ Forum 7 03-09-2010 03:54 AM
WEBER 34 DGEC Carb TOO RICH??, Jets & Tune for Jeep 4.2 / 258 Fjguercio Jeep CJ Forum 55 05-13-2009 01:14 PM
CJ Tech CD discussion, JeepHammer Jeep CJ Forum 11 09-29-2008 07:43 AM
Who is the Weber Tune Guru? b.d.d. Jeep CJ Forum 4 07-26-2008 04:41 PM
Backfire and weber tune help rb85cj7-82cj8 Jeep CJ Forum 4 03-02-2007 08:58 PM
