Weber Set-Up and Tune Discussion - Page 34 - JeepForum.com
 3Likes
post #496 of 1100 Old 08-08-2012, 01:12 PM Thread Starter
swatson454
1983 CJ7
Originally Posted by svenster View Post
Twitching to make progress...
Sorry man.
Yes. Compression test, check spark plugs for oil and excess fuel, ect. Triple check your manifold to head gasket for vacuum leaks. Those can be sneaky little critters!
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #497 of 1100 Old 08-09-2012, 04:04 PM
svenster
compression test done. #1-6. 100/115/115/105/120/110. i used water on the manifold gasket area and found that my idle drops when i pour it on heavy. i tried tightening the bolts and it didn't seem to help a whole lot. weird because the gasket is fairly new because of the recent build. sparks plugs were pretty dark but that would make sense due to running super rich.
svenster is offline
post #498 of 1100 Old 08-09-2012, 04:16 PM
svenster
trying to upload a short video of the vacuum gauge but it won't allow me for some reason
svenster is offline
post #499 of 1100 Old 08-09-2012, 04:51 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Yeah no uploads I know of for videos
Put it o n you tube and imbed the link here.
Like this I think
John Strenk is online now
post #500 of 1100 Old 08-09-2012, 05:04 PM
svenster
svenster is offline
post #501 of 1100 Old 08-09-2012, 05:11 PM
John Strenk
1976 CJ5
compression test done. #1-6. 100/115/115/105/120/110. [b]i used water on the manifold gasket area and found that my idle drops when i pour it on heavy. i tried tightening the bolts and it didn't seem to help a whole lot.[\b] weird because the gasket is fairly new because of the recent build. sparks plugs were pretty dark but that would make sense due to running super rich.
You need to fix this vacuum leak. I got an old BBD that is pulling 20"
Could the bolts you are using too long?
They might bottom out and you would think they are tight. But they are not sealing the manifold.
post #502 of 1100 Old 08-09-2012, 05:11 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
svenster,
15" hg seems low for California. That puppy should pull 18-20 easy at sea level.
I'd still be looking for a leak.
Matt
Matt1981CJ7 is online now
post #503 of 1100 Old 08-09-2012, 05:14 PM
svenster
ok. i feel like i should pull off the intake and have it planed. i have the clifford and the weird washer shim set up. planing would get both surface closer to matching and make sure that i have a level plane to work with. sound right? what intake gasket would be the best so that i won't have to remove the manifold again for the umpteenth time?
svenster is offline
post #504 of 1100 Old 08-09-2012, 05:15 PM
svenster
Originally Posted by Matt1981CJ7 View Post
svenster,
Matt
could my cam have something to do with that being as it is a clifford 264?
svenster is offline
post #505 of 1100 Old 08-09-2012, 05:15 PM
John Strenk
1976 CJ5
I use felpro gasket with no problems.
I use a thin layer of axle grease on the gasket so I can reuse it if I have to take it off again. This only works if the surface is even and you did not over torque the gasket.
It does make removing the gasket years later a cinch.
If you get the exhaust manifold done at the same time, you probably don't need a gasket for the exhaust.
If you have money to burn, take the head in also and have guide pins installed for both manifolds.
post #506 of 1100 Old 08-09-2012, 05:18 PM
John Strenk
1976 CJ5
It could, how aggressive is that cam? What's the overlap?
A good torquey cam should still give you good vacuum.
post #507 of 1100 Old 08-09-2012, 05:20 PM
svenster
head has guide pins for the intake, but not exhaust. rather not pull the head again due to the fact that i have the smaller head bolts and aligning the head to the block so that it didnt leak coolant was a real pita.
svenster is offline
post #508 of 1100 Old 08-09-2012, 05:24 PM
svenster
here it is
svenster is offline
post #509 of 1100 Old 08-09-2012, 05:25 PM
John Strenk
1976 CJ5
Make sure the alignment hole is deep enough when you have the surface planed.
post #510 of 1100 Old 08-09-2012, 05:35 PM
John Strenk
1976 CJ5
here it is
Looks torquey.
If a cam has a lot overlap, the you will get lower vacuum. But You have little overlap but a good lift. Good cam.
Here is factory
Weber Operation Discussion John Strenk Jeep CJ Forum 7 03-09-2010 03:54 AM
WEBER 34 DGEC Carb TOO RICH??, Jets & Tune for Jeep 4.2 / 258 Fjguercio Jeep CJ Forum 55 05-13-2009 01:14 PM
CJ Tech CD discussion, JeepHammer Jeep CJ Forum 11 09-29-2008 07:43 AM
Who is the Weber Tune Guru? b.d.d. Jeep CJ Forum 4 07-26-2008 04:41 PM
Backfire and weber tune help rb85cj7-82cj8 Jeep CJ Forum 4 03-02-2007 08:58 PM
