Weber Set-Up and Tune Discussion - Page 32 - JeepForum.com
 4Likes
post #466 of 1148 Old 07-22-2012, 07:41 PM
mulliflier
Ah, gotcha, no Sean sorry I have been so busy lately that I haven't been keeping up on my JF. Last few months have been really something, just getting caught up now. Matt, thanks for the help, my issue with the idles though is that 45, to my knowledge, is the smallest jet for the 38 (according to Redline anyway). I was originally headed that direction, but Ron told me that there is nothing smaller than a 45, and that regardless, opening up the air correctors is what he recommended. I went with that, since he's the redline bubba and invariably knows more about carbs than I do. I get the jets by mail tomorrow, I'll let you know how it goes. If anyone knows how to obtain a set of idles/mains smaller than 45/145, let me know.
mulliflier is offline
post #467 of 1148 Old 07-22-2012, 08:17 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hmm....I'm not sure what Ron is talking about. The jetting combo that worked best for me, at 6000', was 50 idles, 135 mains, F7/170 air correctors. I wish I had a set of 45 idles to try, I think they'd be even better.
Ask for Tom at Redline.
Matt
Matt1981CJ7 is offline
post #468 of 1148 Old 07-23-2012, 08:12 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Sweet, all you need is an ash bowl and ... nah, better not go there,
You need to machine a carb out of a clear block of plexiglass someday.
Hmmm.....
I had this big clear box and a couple of shop vacs and a carb....
If I only had a Bridgeport..
John Strenk is offline
post #469 of 1148 Old 07-23-2012, 10:34 AM Thread Starter
swatson454
1983 CJ7
Thanks, John
I need to find the right fluid. Water just has too much surface tension and I don't think that sucking flammable rubbing alcohol through a shop-vac is my most smarterest idea to date. I'd also like to line up a high-def video camera and hopefully get some still shots of it in action. The camera phone thing didn't quite cut the mustard.
Any thoughts on a test fluid?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #470 of 1148 Old 07-23-2012, 12:38 PM
86cj74.2L
86cj74.2L's Avatar
The diesel fuel injection test stands I repair use a calibration fluid with same specific gravity and properties as diesel.
Got to be something for gas. Unless thats what they use.
I thought I saw a animation video on it on how stuff works.
It injects air into the stream of fuel going to metering ports.......makes it frothy.
86cj74.2L is offline
post #471 of 1148 Old 07-23-2012, 01:15 PM
uptillnow
uptillnow's Avatar
I have heard that "Stoddard" solvent has been used for testing inplace of gasoline, close equivalent.
UPTILLNOW
Frothy
uptillnow is offline
post #472 of 1148 Old 07-23-2012, 01:23 PM
86cj74.2L
86cj74.2L's Avatar
UPTILLNOW
Frothy
All that is is mineral spirits. And easy to find.
post #473 of 1148 Old 07-23-2012, 07:47 PM
John Strenk
1976 CJ5
And there are many other ways to create a vacuum without a shop vac.
We use a vacuum run off compressed air.
post #474 of 1148 Old 07-23-2012, 08:27 PM
86cj74.2L
86cj74.2L's Avatar
Do you have the cabinet coolers that use compressed air too? Cabinet Cooler is the brand I think.
post #475 of 1148 Old 07-28-2012, 04:34 PM
svenster
so i am now noticing a grip of predetonation(ticktacks-clickclacks) since adjusting my carb and timing. oh, and my choke does not seem to be working anymore. any ideas from the gurus?
svenster is offline
post #476 of 1148 Old 08-02-2012, 05:57 PM
svenster
anybody?
svenster is offline
post #477 of 1148 Old 08-04-2012, 12:44 PM
mulliflier
If you're getting predetonation, I would either double-check your timing and possibly retard it some, check that you don't have some bad fuel, or something along that line. Assuming all else is well, the timing would be my immediate culprit - retarding it even a few degrees might get rid of the pre-det.
Hope that helps a little man, I'm no guru but the real pros seem to be busy.
post #478 of 1148 Old 08-05-2012, 03:36 PM
svenster
ok. timing between 8*-10*, it bounces a little. zero vacuum at ported. idles waaaaay low, around 380. if i turn in the speed screw i lose my zero vacuum. mixture screw at 1 turn out. less pre-det btw though, so that is good... any more help would be greatly appreciated.
svenster is offline
post #479 of 1148 Old 08-05-2012, 03:37 PM
svenster
need to figure out how to increase my idle without losing zero vacuum.
svenster is offline
post #480 of 1148 Old 08-05-2012, 08:46 PM
mulliflier
Use zero vac when finding lean-best if you can, but once that is set, you want to reconnect your vac advance and then set your idle to 600-700. At that point, it doesn't matter so much if there is absolutely zero vac, you might have a few in of Hg of vac but shouldn't be much (like 3in or so I would say is fine.)
Weber Operation Discussion John Strenk Jeep CJ Forum 7 03-09-2010 03:54 AM
WEBER 34 DGEC Carb TOO RICH??, Jets & Tune for Jeep 4.2 / 258 Fjguercio Jeep CJ Forum 55 05-13-2009 01:14 PM
CJ Tech CD discussion, JeepHammer Jeep CJ Forum 11 09-29-2008 07:43 AM
Who is the Weber Tune Guru? b.d.d. Jeep CJ Forum 4 07-26-2008 04:41 PM
Backfire and weber tune help rb85cj7-82cj8 Jeep CJ Forum 4 03-02-2007 08:58 PM
