Weber Set-Up and Tune Discussion - Page 10 - JeepForum.com
 3Likes
post #136 of 1100 Old 01-11-2011, 09:33 AM
mcmud
1983 CJ8
I prefer to shop either of these two. Both will provide fast, courteous service. A phone call will be necessary since neither has the .080 listed on the site, skip the .075.
Contact Anna or Carlos @ the number listed here: http://www.carbsonly.com/frames/webermain.htm or Stephen @ http://www.piercemanifolds.com/
With the DGV having been built with either the "BIG" (74409.xxx) or the "SMALL" (74403.xxx)primary idle jet you would need to confirm which is necessary for that bore. This link will help with determining which you need.
http://www.piercemanifolds.com/category_s/191.htm
W.D.E.!
mcmud is offline
post #137 of 1100 Old 01-15-2011, 11:56 AM
outsider2010
Hello again guys. Last time I checked idle air bleeds were been drilled tapped and brass plugs threaded in with calibrated holes in them I wonder if plugging those bleeds with JB weld and instead drilling the idle jet holders would be better, like the IDAs, you could have several jet holders with different holes and changing settings should be quick and easy, small hoses could run from the heads of the holders to the air cleaner for clean air.
Jorge.
outsider2010 is offline
post #138 of 1100 Old 01-15-2011, 12:02 PM
outsider2010
Also, I was never able to make the F50 tube to work, I tested the F8, F80, F7, F6 and anther one I can recall right now and I was able to make the F6 work well but using small jets all around (for the primary in a 32/36) that is what I'm using now, at the end of the day the weber tuning manual recommends starting with a main that is about 4 times the size of the venturi, in my case that would be a 105 main jet (104 actually).
Jorge.
post #139 of 1100 Old 01-15-2011, 12:11 PM
mcmud
1983 CJ8
Shouldn't that have been read as 4 X the carb bore, as a starting point.
Four times 32mm = 128mm.
Four times 36mm = 144mm
mcmud is offline
post #140 of 1100 Old 01-15-2011, 12:30 PM
outsider2010
Well... the weber tuning manual I have (the white with red lettering) says venturi, I just checked very quickly it must be obsolete then since I haven't opened in a long time, I have not looked to confirm the ratio.
Jorge.
post #141 of 1100 Old 01-15-2011, 12:39 PM
mcmud
1983 CJ8
I wouldn't call it obsolete but I do wonder if that was written in reference to a variable choke & venturi Weber and who the author is.
mcmud is offline
post #142 of 1100 Old 01-15-2011, 12:50 PM Thread Starter
swatson454
1983 CJ7
I have a graph that gives a starting point for main jet based on venturi size as well. Mine's geared for independent runner applications though. Maybe that's the difference.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #143 of 1100 Old 01-15-2011, 12:55 PM
outsider2010
The author is the weber factory, and I have never heard of a variable venturi weber, I'm not saying that it doesn't exist since I'm just an amateur, the only ones I have seen and worked on them are from Stromberg, keihin, SU I have two SU in our MG Midget in the garage, had 2 zenith-stromberg in our 1979 range rover way back when (and never had problems by the way), I know that Ford had one and Chrysler too but never seen them.
Jorge.
post #144 of 1100 Old 01-15-2011, 12:57 PM
outsider2010
Hi Shawn, I put the book away already but I think I saw a multiplying factor to the single cylinder graph for the multi-cylinders.
post #145 of 1100 Old 01-15-2011, 01:00 PM
outsider2010
Ohh I forgot the Amal's in the Triumph
post #146 of 1100 Old 01-15-2011, 01:01 PM
mcmud
1983 CJ8
I see where my confusion is resulting from. It is written as 4 X venturi and then an example 4X32=128, however I always assumed it should be written as bore, since the numbers are in line with what Redline has jetted both the fixed venturi 32/36DGV and 38DGS.
And then I used the term "variable" for the choke and venturi type Webers which you may select and set their sizes.
mcmud is offline
post #147 of 1100 Old 01-15-2011, 01:08 PM
outsider2010
Yes it is confusing since the way we usually refer to these carbs are with the bores, but the graphs are general graphs to fit all webers and it it just our series that doesn't have interchangeable venturis, it is very common to find a 40DCOE with 32mm venturi and another with 36mm both needing different jets (well... maybe or maybe not).
post #148 of 1100 Old 01-15-2011, 02:34 PM
mcmud
1983 CJ8
Lets look at an example using both formulas with the 32/36DGV as well as the 38DGS and then comparing those results with what Redline recommends to be used in our typical 4.2 applications.
DGV 26mm X 4 = 104 and then 27mm X 4 = 108
Since they are staggered, I might assume that we could average the two so that being 26+27=53 time 4 equals 212 / 2 = 105. Redline suggest that we begin at 145.
While considering the bores. 32 X 4 = 128 and 36 X 4 = 144 then if we average those two it equals 136.
While we see that either of these examples fall short of the sizes that are considered the basis with our applications we must remember that the DGV is actually designed for a smaller engine than the 4.2 inline six, however you will see that with the bore being the factor it is much nearer the typical standard.
Looking to the 38DGS, 27 X 4 = 108. Redline suggest 140-150's. When we consider the bores being 38mm X 4 = 152
Then taking those sums a bit farther in the trial to begin fitting the idle jets in a DGV.
While using 105 X .42 we see that the idle jets should be in the range of .044. While using the bore we see that 136 time .42 equals a range of .057 Redline recommends a 075 primary and a 060 secondary.
And with the DGS at the venturi, 27 X 4 = 108 * .42 = .045
Using the bore rather than the venturi, 38 X 4 = 152 X .42 = .063. Redline recommends 055-060
mcmud is offline
post #149 of 1100 Old 01-17-2011, 03:14 PM
uptillnow
uptillnow's Avatar
This is very good information and a great place to start "jetting". The carburetors come from Spain with larger jets than this. I believe it has to do with the pump gas we can expect to run and the sizes of the engines have increased in the US. Good stuff here....
I wanted to comment on the size of the Venturi, as the size increases the depression or the vacuum pulling the fuel decreases, therefore needing a larger jet and conversley when the Venturi size decreases the signal increases needing a smaller jet. Then there is... What does the engine like? Once we start we can go leaner until the engine won't run, or, richer until we are blowin black smoke out the exhaust. Somewhere in the middle of all of this is a cruise Lambda reading and a power reading. This is where we need to tune to our specific needs from our equipment.
This is a great conversation.
Uptillnow
uptillnow is offline
post #150 of 1100 Old 01-17-2011, 03:27 PM
uptillnow
uptillnow's Avatar
P.S.
I know the signal does not pull. The atmospheric pressure push the fuel to fill the void created by the Vena contracta on the venturi. (Bernouli's Principle) Also the air speed (or RPM) has to be considered. This is why I like to respond to the needs of the engine.
tillnow
Weber Operation Discussion John Strenk Jeep CJ Forum 7 03-09-2010 03:54 AM
WEBER 34 DGEC Carb TOO RICH??, Jets & Tune for Jeep 4.2 / 258 Fjguercio Jeep CJ Forum 55 05-13-2009 01:14 PM
CJ Tech CD discussion, JeepHammer Jeep CJ Forum 11 09-29-2008 07:43 AM
Who is the Weber Tune Guru? b.d.d. Jeep CJ Forum 4 07-26-2008 04:41 PM
Backfire and weber tune help rb85cj7-82cj8 Jeep CJ Forum 4 03-02-2007 08:58 PM
