Weber prog jets size. - JeepForum.com
post #1 of 2 Old 09-08-2013, 08:11 AM Thread Starter
Warmacht
I have a 85 cj with the 6cyl 4 speed stick. The OG carb died so a redline weber is what I want to go with. My questions are . What jet sizes for primary,secondary& idle at sea level . Also will the vac port for the distributor be fine with a stock vac advance ? Thanks for all the help.
Warmacht is offline
post #2 of 2 Old 09-09-2013, 12:57 PM
uptillnow
uptillnow's Avatar
The "typical" jetting below 3800 feet is this:
Primary Idle .75mm
Secondary Idle .60mm
Both Mains 1.40mm (or, P 1.40mm S 1.45mm)
Primary Air Correction jet 1.70mm
Secondary Air Correction jet 1.60mm
With the stock ignition Duraspark, timing is 8-10 BTDC (some say 10-12 BTDC) with the "S" ported vacuum source to the right of the choke housing down toward the mounting flange.
Some like the manifold vacuum for the advance. Initial timing would then be 8 BTDC, then the manifold vacuum hooked up and it will go off the scale. (22 BTDC ?)
Do not allow your engine to "ping", pre-ignition is cumulative, meaning every ping adds up to the big bang. NO PRE-IGNITION!
Good Luck.
UPTILLNOW
uptillnow is offline
