Weber K551 34/34 DGEC idle problems - JeepForum.com
post #1 of 51 Old 07-23-2008, 10:38 AM Thread Starter
TripEph
1983 CJ7
i have a rebuilt motor (258), and new ignition parts, but the carb will not idle properly. Once I am going, the carb seems to run fine through all the gears, but every time i slow to a stop, the carb just sputters out and dies. I did a search, and found things about different jets, and vacuum leaks. Are one of these my problem? When I first start the jeep, it seems to run ok for a little, then the idle kinda bounces around a little, the engine struggles and then stalls. Every time I start it up after this, it just sputters out. Any help would be greatly appreciated.
TripEph is offline
post #2 of 51 Old 07-23-2008, 12:52 PM
valkadesh
Do you have the idle mixture set appropriately? That's the first thing i'd check. The instructions should have come with your carb. If the mixture is way off, that would be a possibility. It's an easy adjustment. I'd start there first.
valkadesh is offline
post #3 of 51 Old 07-23-2008, 09:10 PM
CGrugger
CGrugger's Avatar
mine does that too, it works about half the time and the other half it sputters out and dies at traffic lights. I look like i cant drive stick. It has been working lately, and all i have done is try to adjust the mixture better.
2005 TJ X: 2" RE spacer lift, 32"x11.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is offline
post #4 of 51 Old 07-23-2008, 09:16 PM
CJhollic
1980 CJ7
I would look close for vacuum leaks.Spray some wd 40 around the base of the carb and see if the motor has a noticeable difference in the way it runs.
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #5 of 51 Old 07-24-2008, 08:10 AM
littlebuddie
1980 CJ7
I had the same problem. You must follow the set-up sequence as noted here: http://www.carburetion.com/Weber/adjust.htm
But do check for vacuum leaks as CJhollic suggested.
littlebuddie is offline
post #6 of 51 Old 07-26-2008, 04:33 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
not one mention of a fpr..fuel pressure regulator..One needs to be installed and adjusted down to about 3lbs. to get the most out of the carb..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #7 of 51 Old 07-26-2008, 04:38 PM
WolfDawg
I've got this same carb and have had nothing but trouble out of it. I finally got it running smoothly, but it just runs WAY too rich and the exhaust fumes kill me. As soon as I can afford it, i think I'm going with fuel injection....but to get mine running even as well as it is a guy had to clip some of the springs out of the idle mixture screw to get more adjustability out of it and we sized the jets down to 45 in the primary and 47.5 in the secondary. I think that it would be better with a 40 in the primary and the 45 in the secondary myself, but that's just a theory....
WolfDawg is offline
post #8 of 51 Old 08-15-2008, 06:56 AM
foot0x029a
I just installed this same carb in my '88 YJ a couple of days ago; one thing that got me started was to crank the choke screw all the way in, so you might want to try that.
Now it's running smoothly, but way too rich, so I'm planning on backing off the choke until it sputters, then trying to re-adjust the idle mixture according to the carburation.com link posted above (thanks!)... the setup instructions (and blurry pictures) included with the carb weren't the best.
foot0x029a is offline
post #9 of 51 Old 08-15-2008, 07:01 AM
DT5150
1983 CJ7
could be the fuel filter as well.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #10 of 51 Old 09-03-2008, 06:47 AM
unclet
Hei
My 90 yj with the weber did the very same thing yours and after instaling an HEI distributer, it runs like a top and I'm waiting to see if my MPG increase.
unclet is offline
post #11 of 51 Old 09-03-2008, 10:50 AM
SuB8HaVeN
It runs rich because you don't have a FPR installed. Even adjusted all the way lean, without a FPR the Weber will run way too rich.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #12 of 51 Old 09-15-2008, 12:44 PM
OldeJeeper
1987 YJ Weber
I did the K551 conversion too, and it runs fine after I did the setup by the guide mentioned in some earlier post, and cranked the choke release screw way in. I also had to jet down to 45 pri 47.5 secondary to lean it out. My remaining problem is a tendency to flood while it sits in a parking lot after a 30 mi drive. Takes way too much cranking to clear the manifold, but it does finally start. I don't have a FPR in now, but I do have one of those fuel filters with a tank return at the Weber inlet. Stock fuel pump. I tried a Specter $25 regulator (Chinese junk!), but it just arbitrarily cut the fuel off completely at idle, so I put the tank-return filter back in. Weber says to use a regulator but doesn't recommend a reliable choice. Any suggestions? Is there any Web info on checking/setting the float level for a 34 DGEC?
OldeJeeper is offline
post #13 of 51 Old 09-15-2008, 12:48 PM
Mike Romain
Man, I sure like my BBD......
Mike
Mike Romain is offline
post #14 of 51 Old 09-15-2008, 01:48 PM
OldeJeeper
Yeah, I actually had my BBD running quite well after a season of rough idling. I took it apart and found a bunch of naptha crystals adrift in the floatbowl. After cleaning them out it idled and ran fine during the summer. I just did the Weber conversion for smoother acceleration and better cold-weather starting. My BBD's choke was cantankerous in winter.
I'm wondering if the Specter-type inline regulators are supposed to tee off the inlet line and go to the tank-return, instead of being in the line to the carb?
post #15 of 51 Old 09-21-2008, 12:31 PM
rj_ton
Answer to all pump and regulator problems
There is always one debate when installing a Weber. Check this page out.....
www.racetep.com/webfuelspark.html#webfuel
It shows how the Carter 4070 rotary electric pump is the one simple answer to this reoccuring question. It is a high volume low pressure rotory pump (constant flow, not a pulse like other crappy elec. pumps or like the stock mechanical pump.) Regulators only decrease the life of a pump. So why not find a pump that operates at your needs? The 4070 pumps at around 4psi but flow around 60-70 gph. Perfect for what any weber needs! It costs around $80- $100 and comes with everything you'll need except a little extra hose and wires. When I found this I was sold, I bought my Weber, did the Nutter bypass and only a little adjustment. Make sure the remainder of your vacuum lines that you use are routed properly and reset your timing on your distributer 14 degrees BTDC @1600 rpm.
Cheers
rj_ton is offline
weber 34/34 dgec jets avalance Jeep CJ Forum 3 08-03-2016 10:19 PM
Weber 34 DGEC MuddyMules Jeep CJ Forum 10 04-20-2013 01:18 PM
Weber K551 34 question RynoG4 Jeep CJ Forum 5 10-27-2007 12:17 PM
Weber 34 DGEC conversion Help daoliv Jeep CJ Forum 4 03-08-2007 01:45 PM
Weber K551 or K551-38 (hi-po)? jmerlick Jeep CJ Forum 3 11-25-2004 04:48 PM
