weber idle HELP! - JeepForum.com
post #1 of 2 Old 09-26-2011, 10:36 AM Thread Starter
mastercraft29
weber idle HELP!
Whats up guys... I cannot figure out what the f is wrong with my weber! I took it off cleaned out all 6 jets (there was some build up in like 2) so i thought that was the problem but it still wont idle.. If i just barely give it gas it will stay running but as soon as i let if off it dies and sometimes white smoke comes out of the carb? I didnt want to mess with the idle screw or any of the mixture screws but it looks like i may have to.. Is there one of the mixture screws I should have taken out and cleaned?? something else I thought of, I have the HEI distributor with the nutter bypass, and I know the HEI puts out a lot more heat than the stock one but my battery was dead so I charged it and let it sit for a few days then i had to charge it again, so my question is if this battery isnt strong enough or something could it be possible that its not putting out enough juice?? I have two other posts on this problem if you have any questions... PLEASE HELP!
mastercraft29 is offline
post #2 of 2 Old 09-26-2011, 11:15 AM
mcmud
1983 CJ8
Not trying to adjust the carb is the same as saying; I refuse to attempt to put an end to this frustration.
Is there one of the mixture screws I should have taken out and cleaned?? .......................
If this is a 32/36DGEV, there is only one mixture screw and yes you should remove it.... first in an attempt to get over the fear of doing that and just in case there is a clog inside.... attempt to clear it. <---- Clearly spelled out in one of your previous threads.
mcmud is offline
weber 38 high idle ms198 Jeep CJ Forum 7 02-08-2011 07:28 PM
Weber carb IDLE HUKEMBEVO Jeep CJ Forum 4 06-28-2009 01:18 PM
Idle Mix and Idle Speed on Weber jennandal Jeep CJ Forum 2 01-28-2008 08:41 PM
WEBER Idle ? phil77 Jeep CJ Forum 7 09-19-2007 08:24 PM
Weber fast idle CJay7 Jeep CJ Forum 3 12-10-2006 05:50 PM
