WEBER Carb Pics... - JeepForum.com
post #1 of 31 Old 04-02-2008, 10:00 PM Thread Starter
breakthru
WEBER Carb Pics...
Can someone direct me to some pictures of installed Weber 34/34 carbs... especially their linkage on a CJ. Thanks.
Casey
breakthru is offline
post #2 of 31 Old 04-03-2008, 07:49 AM
SuB8HaVeN
There's my Weber 34/34. I know, my engine bay is a mess. I still haven't cleaned it from the last time I went wheeling. But note the Holley fuel pressure regulator. You will need one for the Weber 34/34, I got mine from Summitracing.com. Also, for the spring, I just attached it to that bracket on the intake manifold. Works for me.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #3 of 31 Old 04-03-2008, 08:22 AM
CJ Chet
Don't worry about the linkage. Just remove it and run the cable right to the carb.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #4 of 31 Old 04-03-2008, 08:24 AM Thread Starter
breakthru
thanks so much!
post #5 of 31 Old 04-03-2008, 08:25 AM Thread Starter
breakthru
what's a fuel pressure regulator do? I don't have a computer anymore, will that affect the need or no need for one?
Casey
post #6 of 31 Old 04-03-2008, 09:25 AM
SuB8HaVeN
What happens is that your stock fuel pump is designed to give the stock Carter BBD 7psi of fuel, and the Weber is only designed to handle 3-3.5psi. I ran my Weber 34/34 without a FPR for a while, but it ran rich as could be and never ran right. After installing the FPR, it seemed like I just gained 50hp and no more running rich!
post #7 of 31 Old 04-03-2008, 11:20 AM
CJ Chet
X2! Just make sure it's a HOLLEY regulator (Mr Gasket is garbage).
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #8 of 31 Old 04-03-2008, 11:51 AM
Mike Romain
Someone should put a pressure gauge on the stock fuel filter's output. Remember the center outlet goes to the carb at full flow for the tube's size and the 'top' outlet goes back to the gas tank.
I was told it is a metered output to the return line restricting the back flow so the carb sees 4.5 psi 'if I remember right', and upon inspection confirmed this visually. The outlet to the return line has a metered hole in it about 50% of the opening's diameter. The carb output is full flow.
I was thinking that this hole could just be expanded until the leftover going to the carb couldn't go above 3.5 psi.
Some days I think too much too though, but...?
Mike
Mike Romain is offline
post #9 of 31 Old 04-03-2008, 12:23 PM
CJ Chet
This works well:
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #10 of 31 Old 04-03-2008, 12:47 PM
SuB8HaVeN
Amen brother, don't buy anything but the Holley. I bought the Mr. Gasket from Advance auto parts and that thing was leaking a river of fuel out of the regulator. Garbage...
post #11 of 31 Old 04-03-2008, 03:18 PM Thread Starter
breakthru
Anyone got a link or part number to this Holley FPR? Thanks.
post #12 of 31 Old 04-03-2008, 06:56 PM
CJ Chet
Ask and ye shall receive!
http://store.summitracing.com/partde...5&autoview=sku
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #13 of 31 Old 04-03-2008, 08:26 PM
86cj7jgn
Hey Cj Chet,
Nice install on the regulator, gauge & filter. What size fuel hose did you use?, and, where did you get that K&N filter? Do you have a PN# for it? I have looked everywhere for one with a weber base.
Thanks
86cj7jgn is offline
post #14 of 31 Old 04-03-2008, 08:42 PM
Indy
Indy's Avatar
I run the extra inlet as an overflow back to the tank, never had a problem with too much pressure.
I'm the only gay eskimo.
Indy is offline
post #15 of 31 Old 04-04-2008, 06:08 AM
CJ Chet
Originally Posted by 86cj7jgn View Post
Hey Cj Chet,
Thanks
That's standard 3/8" fuel injection hose. I had to fabricate the filter base. I used the bottom piece of a Mr. Gasket unit. Using a piece of phenolic board, I had it laying around, I traced and cut out the Weber shape and fixed it into the bottom of the Mr. Gasket piece using small screw and epoxy. Once you have that you can just order the K&N filter and Extreme Flow top by SIZE rather than application. It flows QUITE nicely.
BTW: I also put a bead of RTV around the bottom (let it set up real good before installing) to act as a seal to the carb (like an o-ring).
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
Weber carb Help! bushCJ7 Jeep CJ Forum 19 01-28-2009 12:22 PM
Weber Carb Help! cfljeep Jeep CJ Forum 11 03-01-2008 06:53 AM
weber carb ? phil77 Jeep CJ Forum 14 04-08-2007 08:38 PM
Weber Carb Help h2obuff Jeep CJ Forum 1 04-10-2006 01:29 PM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 12:34 PM
