weber carb install help - JeepForum.com
post #1 of 5 Old 11-30-2011, 05:30 PM Thread Starter
hevyford2
1974 CJ5
hey guys new to the forum wanted to say hello. i need some help i have a 1974 cj5 with a 258. my carter carb took a dump so went to the junk yard and found a brand new weber two barrel with plentum. the weber carb has a plugin on the back that my cj doesn't have. can i bypass this plugin and what is it for.any help will be great thanks. oh yeah how do you post pics so i can show what i have
hevyford2 is offline
post #2 of 5 Old 11-30-2011, 06:07 PM
keith460
Jeep. There's Only One
keith460's Avatar
Are you sure it's a Weber and not a two barrel Carter with the Stepper Motor? Weber's have a connection for the Electric Choke version and maybe an add on for a Idle Jet Solenoid for cutting of the fuel to the carb if your vehicle is "dieseling".
1984 CJ-7 Renegade
keith460 is offline
post #3 of 5 Old 11-30-2011, 07:59 PM Thread Starter
hevyford2
1974 CJ5
weber
well it says on the side carter/weber. and doesn't the steper motor have gears on the carb. i wish i could post a pic but dont know how
post #4 of 5 Old 12-01-2011, 07:37 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Below the reply box is a "Upload Image" button. Click that. A small window should pop up that allows you to select up to 5 pictures per post. Once you the select the pictures, click on the "Upload" button within that little box.
When the pictures are done uploading, their names will appear just below the replay box. Then you can post the reply, as usual.
Hope this helps.
Matt
Matt1981CJ7 is offline
post #5 of 5 Old 12-01-2011, 11:24 AM
Attwanl
Should be some numbers on it.... Mine are near the base plate.
What happened?
Attwanl is offline
weber carb help on my CJ5 Beninpcb Jeep CJ Forum 8 07-29-2010 04:54 PM
Weber Carb Help jeepguy85 Jeep CJ Forum 6 05-10-2010 01:34 PM
Weber Carb... CJmadison Jeep CJ Forum 10 03-14-2006 08:47 AM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 01:34 PM
Just got a Weber carb...need help please cjthor Jeep CJ Forum 1 06-19-2003 05:20 PM
