Weber carb help - JeepForum.com
post #1 of 10 Old 08-12-2017, 07:24 AM Thread Starter
moparmagic
Weber carb help
Many of you have probably seen some of my earlier post, but just a little back ground. I have a 85 jeep cj7 4.2, auto trans, headers and a weber 38dges on it. Not real sure what the PO has done and not done. It has the nutter bypass on it and the rush upgrade. I have been struggling to get it to idle without turning the idle screw in so far that it exposes ports causing the carb to drain when the engine is off. I have read all the info I can find on tuning and nothing seems to help. I have even drilled the throttle plates( not sure if I did something wrong but seems to have made matters worse). I'm either thinking of replacing the throttle plates and trying a rebuild or replacing with a motorcraft 2100? Can you replace the throttle plates? If so where can I buy them? Any suggestions? I don't have a lot of money available at this time to put in it. Looking for a cheap fix if that's possible. I have seen the carb kits on ebay but I don't have 300.00 to put in it right now!
moparmagic is offline
post #2 of 10 Old 08-12-2017, 07:43 AM
swatson454
1983 CJ7
Are you at least at 12* initial timing and manifold vacuum to the distributor?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #3 of 10 Old 08-12-2017, 09:07 AM
stripperguy
What intake manifold do you have?
What size hole(s) did you drill?
Do you have manifold vacuum for your distributor? If so, does the rpm rise when you disconnect the vacuum line?
Do you know the idle jet size? (they're clearly marked, only takes a minute to pop them out)
1977 CJ5 is a CJ build ever really done?
2002 TJ gone
2005 TJ also gone
2005 LJ insurance wreck
stripperguy is offline
post #4 of 10 Old 08-13-2017, 04:13 PM
NittanyGen
Shawn
At least 12*? I thought it was supposed to be 8 or 9? I only ask because I have same carb and have issues as you know. Why should it be 12 degrees?
Sent from my SAMSUNG-SM-G891A using Tapatalk
NittanyGen is offline
post #5 of 10 Old 08-13-2017, 06:24 PM
swatson454
1983 CJ7
He needs all the help he can get to keep the rpm from dropping too low when he puts it in Drive.
Shawn
post #6 of 10 Old 08-13-2017, 11:07 PM
whollsee
1982 CJ7
10* +/- 2* for auto on my engine bay decal and that is without mods remember. 12* works very well for me with mods.
When ever I hear the word 'Jeep' I reach for my wallet.
whollsee is offline
post #7 of 10 Old 08-14-2017, 01:03 AM
BagusJeep
1981 CJ7
Originally Posted by moparmagic View Post
85 jeep cj7 4.2, auto trans, headers and a weber 38dges o - nutter bypass on it and the rush upgrade. - I have even drilled the throttle plates
Sounds like a good setup, no need to replace anything on there. The hole in the throttle plate can be soldered back up if you need to, no big deal or cost. However, unless it was a gigantic hole, it is unlikely to be your problem.
You need to start with the basics of an idling engine first and check the real ignition timing (the timing marks have to be verified by measuring piston movement, do not ASSUME they are right as they can shift). Then check for vacuum leaks, they can cause all sorts of issues. As it is a 1985 it came with yards of leak prone hoses, sort out what you have and then DISCONNECT IT, except for the connection to the distributor vacuum advance you may want to try with all vacuum ports plugged, also check around any adapter under the carb. I have had these leak as they are sometimes not totally flat.
Now check your idle jets for size, something around a 50 or 55, if they are in the ball park it should idle without any opening of the throttle butterfly.
One good tool for setting up the idle is a vacuum gauge, it may give you some idea what is happening inside the manifold. You can also connect it to the port just above the throttle to verify it is shut, you will have a little vacuum as you have a hole in the butterfly but it is really important to make sure the butterfly is below the progression hole i.e. shut or almost shut.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 10 Old 08-14-2017, 05:25 AM
whollsee
1982 CJ7
A little vac may not hurt at all. I did worry that holes in the butterflies would still see vacuum at idle even if progression holes are covered. Not so. Getting a 0" reading at idle when I finally got to checking last weekend- with 1/8" holes. Blip up to 6" on revs then straight back to flat. I think Stripperguy on his tuning thread reported the same. Perhaps... if the prog orifi are covered by the edge of the plates then the S-port is sealed off regardless.
whollsee is offline
post #9 of 10 Old 08-14-2017, 06:04 AM
swatson454
1983 CJ7
I agree: holes in the throttle plates won't pull a vacuum on the s-port.
Shawn
post #10 of 10 Old 08-14-2017, 06:17 AM
stripperguy
Where did you go Mr mopar (or is it Mr maggic)??
I can't speak for everyone, but I'm anxiously awaiting your tuning results...
2002 TJ gone
2005 TJ also gone
