weber carb - JeepForum.com
post #1 of 5 Old 08-31-2007, 12:18 PM Thread Starter
kevbo
weber carb
trying to decide on a carb for my cj.its a 258 single brl intake fresh complete rebuild headers 4 :11 gears on 35's . like most of the threads i've seen i want the most torqe and i'm too worried about the fuel eco.this cj is not a daily driver but i am conserned about high angle flooding. i know i cuold go with efi but the initial cost is somthing i cant swallow .any advice would be greatly appreciated
kevbo is offline
post #2 of 5 Old 08-31-2007, 12:38 PM
tcourdin
tcourdin's Avatar
I run the Weber 38/38 on my 258. It works great. Off idle response is excellent, I havent had any issues at all out of it. It hasn't flooded out or stalled yet on an incline.
88 Wrangler, Rebuilt I6, NV3550,Atlas 2,B&M Shifter,38/38 Weber, Skyjacker Lift & Nitro Shocks & Stabilizer, Black Diamond Discos, 35 " Regul MT's & Outlaw 2 Alum Wheels, 4.88 Gears, Dana 35 & Super 35 kit & Detroit Soft Locker, Dana 30 & Superior Axles & Detroit Soft Locker & No Disco, SRC Front & Rear Bumpers, SRC Side Armor, Warn XD 9000 I Winch & In Cab Controls, OR Fab Tire & Can Carrier, Rock Hard 4x4 Full Cage, Hood Rack & Hi Lift & AX, Outland Seats, KC & Silverstar.
tcourdin is offline
post #3 of 5 Old 08-31-2007, 01:21 PM Thread Starter
kevbo
weber carb
did you use it straight out of the box and did you you have to use an electric fuel pump and reg. thanx for the info
kevbo is offline
post #4 of 5 Old 08-31-2007, 05:36 PM
SuB8HaVeN
I have a Weber 34/34 right out of the box with no fuel pressure regulator and mine runs amazing. It doesn't hesitate or studder at all on inclines...
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #5 of 5 Old 08-31-2007, 07:15 PM
wwhitby
1979 CJ5
I run a Weber 32/36 on my CJ. I didn't need an electric fuel pump (just my stock Jeep one), but I do use a fuel pressure regulator. The Weber is set up for about 3.5psi and the fuel pump puts out @7psi.
The Weber was easy to install and tune. I haven't had any problems with it at all!
Warren
Warren Whitby
1979 CJ-5 "Big Blue"
Real Jeeps have rust
Just Empty Every Pocket
wwhitby is offline
Weber carb All 4 Go Jeep CJ Forum 18 05-19-2013 07:02 AM
Weber carb on 232 glassyjeep Jeep CJ Forum 12 06-05-2009 08:30 AM
weber carb ? phil77 Jeep CJ Forum 14 04-08-2007 09:38 PM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 01:34 PM
for those using a weber carb rwcloukey Jeep CJ Forum 29 04-09-2003 04:51 PM
