Weber carb - Page 2 - JeepForum.com
post #16 of 19 Old 05-18-2013, 12:54 PM
Lastvance
Oh yeah it has a Weber Carb on it as well
Just Empty Every Pocket
Lastvance is offline
post #17 of 19 Old 05-18-2013, 07:06 PM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
Originally Posted by swatson454 View Post
Please don't open the pandora's box that comes with cheap regulators. Simply use the OEM bypass fuel filter and you'll be good to go.
Shawn
I just finished walking through this step by step with the instructions from weber on mine. When I finished I had the best running jeep engine I have had in my life. It felt really good to have done it myself.
Just don't skip steps in the instructions, I had my timing at 8 degrees BTDC and when it says to ignore you idle when adjusting best lean idle at first listen to the instructions. I let a "mechanic friend" try to tune it first his way to "save me some time". I should have just followed the directions from the beginning. I pulled up to his shop after I did it and went in to get him, he said fire it up and let's hear it ..... I said "It is running!"
Shoulda seen his face at how smooth it was with no hiccups or stutters.
Good Luck!
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #18 of 19 Old 05-18-2013, 07:59 PM
swatson454
1983 CJ7
Well, every once in a while a good regulator has got to come off the assembly line. I'm glad you got ahold of it.
This begs the question, though: was it the regulator or paying careful attention to the initial tuning? I know where my money is
Either way, congrats on a happy Jeep
Shawn
Edit: Halo, I may have misread your post and confused who did what. If you nailed it by doing what you did without a regulator, awesome work, dude!
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #19 of 19 Old 05-19-2013, 06:02 AM
rcsutton
2010 JK Wrangler
I had a electric fuel pump with factory filter and needed the regulator. Once I installed carb did not run rich anymore. I have recently installed a FAST EZ EFI fuel injection and like it alot. + 20 HP feels like. Weber is almost as great too.
2010 2 door JK Red Rubicon.
rcsutton is offline
Weber carb on 232 glassyjeep Jeep CJ Forum 12 06-05-2009 07:30 AM
Weber Carb Help! cfljeep Jeep CJ Forum 11 03-01-2008 06:53 AM
weber carb ? phil77 Jeep CJ Forum 14 04-08-2007 08:38 PM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 12:34 PM
for those using a weber carb rwcloukey Jeep CJ Forum 29 04-09-2003 03:51 PM
