Weber carb - JeepForum.com
post #1 of 19 Old 09-19-2004, 07:55 PM Thread Starter
All 4 Go
YJ Wrangler
Weber carb
Hey I have a Weber carb k551 it has a fuel regulator in the line...what do you think it should be set at? It goes up to five.
ALL4GO
All 4 Go is offline
post #2 of 19 Old 09-20-2004, 04:26 PM
johny1i
johny1i's Avatar
I have mine set to about 3 or 3.5, and it flows enough to run 70 mph down the road, but yet still not have any problems with the fuel pressure overwhelming the bowl float and dripping. I wound up buying a 4 or 5" vacuum gauge that doubles as a fuel pressure gauge from Advance Autoparts and it makes setting the pressure easy. Make sure you have the gauge hooked up inline with the fuel line to the carb, not disconnected from the carb and connected to the gauge (hope that makes sense).
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #3 of 19 Old 03-19-2013, 08:25 PM
Speedbump1
1983 CJ7
Hey guys, I just bought a Weber 551-38 Conversion Kit. I have it installed, and am finishing up the nutter bypass. I have been reading these posts and am curious about the complaint of it running rich. It was my understanding that these kits come ready for a stock 258 with the ability to upgrade to higher performance if the need is there, example: header, cam, etc. Am I wrong?
Speedbump1 is offline
post #4 of 19 Old 03-20-2013, 05:41 AM
BagusJeep
1981 CJ7
Yes and no.
They come with a standard set of jets and tubes that should maybe run fine, but it depends on where you are, what elevation you are at, temperature etc. Plenty of threads on here about tuning said carb, they are quite starightforward because Weber placed the bits you need to cahnge mostly on the outside where you can get at them.
If you increased the flow the extra venturi size is there. As it is a synchronous operation instead of progressive you can develop more torque low down and have that larger venturi available low down. Downside is that the larger venturis trade off some responsiveness and hence economy.
i have one and like it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 19 Old 03-20-2013, 07:51 AM
Speedbump1
1983 CJ7
Glad to here you like it BagusJeep. I was getting mixed messages on those I have read about on this site who have done the conversion. I wanted to go fuel injection but the cost for me was the deciding point. Is it a good idea to do the HEI distributor, too? If I do that then can I do away with my Ignition Module under my washer reservoir? Not sure if i'll need it or not. Basically my intent is to clean under the hood as much as possible.
post #6 of 19 Old 03-20-2013, 09:13 AM
Renegade82
1982 CJ7
I have the k551 waiting to be put on. Now I've read that sometimes you need the regulator, sometimes not. What usually makes one need it and which regulator are you using?
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #7 of 19 Old 03-20-2013, 11:15 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes, do the HEI conversion or the Team Rush. Won't do you any good to put gas in the engine if it doesn't burn...
John Strenk is offline
post #8 of 19 Old 03-21-2013, 08:37 AM
CJ Chet
Weber says their carb needs NO MORE than 3.5 PSI fuel pressure. If you have a stock pump, you need a regulator. Some guys say you don't, but I'm gonna go out on a limb and assume that Weber knows what they are talking about. BTW: get a HOLLEY regulator, everything else is just junk and MR. Gaskett is the bottom of the pile!
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #9 of 19 Old 03-21-2013, 08:48 AM
Renegade82
1982 CJ7
So it's the Holley 12-804 model? The only low pressure one Summit carries. 1-4psi
post #10 of 19 Old 03-21-2013, 08:56 AM
swatson454
1983 CJ7
Please don't open the pandora's box that comes with cheap regulators. Simply use the OEM bypass fuel filter and you'll be good to go.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #11 of 19 Old 03-21-2013, 09:11 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
This ^^^. The bypass filter acts as a regulator. It should provide about 3.5 psi with a stock mechanical pump.
I ran my 38 with only the bypass filter, and with a regulator. There was absolutely no difference. I liked having the regulator just to have a quick visual check of pressure.
Matt
Matt1981CJ7 is offline
post #12 of 19 Old 03-21-2013, 09:34 AM
Renegade82
1982 CJ7
Okay, makes sense. So the Weber will only "except" the pressure it needs and any excess will be pushed out the bypass and back to the tank. Correct? Good, that saves me $48 for a reg. and gauge, and I already have the stock bypass filter. Thanks guys.
post #13 of 19 Old 03-21-2013, 12:21 PM
keith460
Jeep. There's Only One
keith460's Avatar
Shawn
There's your answer right thar!
No need for a FPR if using OEM type fuel filter with a return line. I bought the Weber recommended FPR but never used it and it cost me around $70.00.
I bought a Viton needle and seat for the Weber as they can take the constant hammering that the factory fuel pump pressure has a tendency to do. Cost, about $12.00.
1984 CJ-7 Renegade
keith460 is offline
post #14 of 19 Old 03-22-2013, 03:21 AM
BagusJeep
1981 CJ7
Ditto, ditto, ditto.
The factory fuel filter works fine on mine, will eventually get around to the Viton seal.
if you have an electric pump, find out if supplies more than 7 psi. If so then you may need a regulator even with the factory filter.
post #15 of 19 Old 05-18-2013, 12:53 PM
Lastvance
What should I set my timing at on my 1985 CJ-7 Laredo with 258 and auto trans.
Just Empty Every Pocket
Lastvance is offline
Weber carb on 232 glassyjeep Jeep CJ Forum 12 06-05-2009 07:30 AM
Weber Carb Help! cfljeep Jeep CJ Forum 11 03-01-2008 06:53 AM
weber carb ? phil77 Jeep CJ Forum 14 04-08-2007 08:38 PM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 12:34 PM
for those using a weber carb rwcloukey Jeep CJ Forum 29 04-09-2003 03:51 PM
