Weber 551-34 - JeepForum.com
post #1 of 9 Old 02-26-2013, 09:18 AM Thread Starter
blaylock6502
Weber 551-34
I am considering purchasing what is supposedly a lightly used weber 551-34 for my 74 258? Is this a good move? How does it compare to the 32/36 I hear so much about? I cannot find it on webers sight.? Is 175 a good deal? In good shape and includes all linkage and adapters.
blaylock6502 is offline
post #2 of 9 Old 02-26-2013, 09:55 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The 34 is a Weber knockoff, made by Solex. The quality is generally considered to be inferior to a true "Made in Spain" Weber. I wouldn't pay $175 for one.
Get in touch with Tom, at Redline, and buy the real McCoy.
Matt
Matt1981CJ7 is online now
post #3 of 9 Old 02-26-2013, 10:06 AM Thread Starter
blaylock6502
Thanks buddy I appreciate it! Which do u recommend?
post #4 of 9 Old 02-26-2013, 10:10 AM
Matt1981CJ7
1981 CJ7
The Weber 38 is by far my favorite carb for a 258.
Matt
post #5 of 9 Old 02-26-2013, 11:02 AM
steve1973
1973 CJ5
I have the 34/34 on my 73. It replaced the 1bbl carter and it works fantastic. I believe i bought it new for $225. I'd offer them $75 for the used one,
steve1973 is offline
post #6 of 9 Old 02-26-2013, 06:01 PM
cj5huntingrig
1974 CJ5
X2 on the Weber 38 but go ahead and buy a jet pack kit and F7 venturis from Redline Weber. Youll thank me later. Also changing to the alum. 2 barrel intake from a newer model 258 will make worlds of difference. Cheers. Evan
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #7 of 9 Old 02-26-2013, 06:13 PM
poppatello
I hate my Weber. I have it on my 4 banger and I have the 32/36 model. Stalls on climbs. I am told the fix is to turn the carb 180 degrees so it stalls on the down grade or replace it. It is not a good off road carb. If you don't wheel then overlook my post...
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #8 of 9 Old 02-26-2013, 06:21 PM
Matt1981CJ7
1981 CJ7
You've been told wrong.
And your problems are more likely with how the carb is setup, than with the brand name.
Matt
post #9 of 9 Old 02-26-2013, 08:18 PM
BlueRubiconrich
webers like to run a fuel pressure of 2.5. You might need a fuel pressure regulater.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
