Weber on 360? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Weber on 360?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Aluminum BumpersThe RuffStuff "I can't go to EJS" Sale!
Unread 08-14-2013, 03:17 PM   #1
MudLover
Weber on 360?
Hey guys! Just getting back into the CJ game after about 8 years away from it. I picked up a 79 CJ5 with a 360 in it. I just ordered the rebuild kit for the Motorcraft 2150 it has on it. I just found the Weber I had on my last CJ. Anyone been able to adapt the Weber to the 360 or is it reserved just for the 258?
Thanks!
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
[B][COLOR=darkred]Red Jeep Club Member #2[/COLOR][/B]
MudLover is offline   Reply With Quote
Unread 08-14-2013, 06:21 PM   #2
superj
1987 YJ Wrangler
You can put any carb on any engine. Just make sure you know your not running to lean
A cowardly leader is the most dangerous of men- Stephen King.
"Just because something isn't a lie does not mean that it isn't deceptive. A liar knows that he is a liar, but one who speaks mere portions of truth in order to deceive is a craftsman of destruction". --I am not sure who said this but it properly describes our president.
superj is offline   Reply With Quote
Unread 08-14-2013, 07:08 PM   #3
swatson454
swatson454's Avatar
1983 CJ7
That's an awfully small carb for a 360.
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now   Reply With Quote
Unread 08-15-2013, 04:24 AM   #4
John Strenk
John Strenk's Avatar
1976 CJ5
Not if he puts enough of them on.
I think a pair of IDA's would work great.
I often wonder though, some 304's came with the BBD, Anyone try a Weber 38 on one of those?
John Strenk is offline   Reply With Quote
Unread 08-15-2013, 07:12 AM   #5
superj
1987 YJ Wrangler
i took a two barrel of a dodge 340 and bolted it to my jeep and it worked great. a little tuning with the vacuum gauge and my gas mileage went from single digits to 13 and my jeep would smoke the tires through the intersection if i stomped on it. (i have an automatic, by the way) after a while, the carb started getting white powdery deposits so i pulled it to clean and rebuild again and the mixture screws snapped off. that is what led me to swap to a holley four barrel, or i would still be running that badass two barrel that came off that old dodge motor.
but, point of message, they put little two and one barrels on big ol' v8s from the factory so you can too, just make sure and read your plugs so you don;t run to lean or rich and burn stuff up.
Unread 08-15-2013, 08:53 AM   #6
uptillnow
uptillnow's Avatar
Thanks!
I found this adaptor, and a 1/4" thick mounting gasket that will adapt your 38-DGES to the MC2100 mounting flange.
I agree with Shawn, this Weber 38-DGES and the MC2100 are a little small for higher RPM range, although both are very tunable and will work GREAT for lower RPM's. Lots of torque.
The 38-DGES and the MC2100 are the same size, so if you have a Weber 38-DGES, and don't want to, can't, won't rebuild the MC2100 use the Weber.
Good Luck with your conversion,
UPTILLNOW
uptillnow is offline   Reply With Quote
Unread 08-15-2013, 08:56 AM   #7
uptillnow
uptillnow's Avatar
Whooops...
I had to decrease the size of this picture for it to upload.
Here is the adaptor for the Weber to the MC2100 mounting flange.
UPTILLNOW
Unread 08-15-2013, 09:57 AM   #8
John Strenk
1976 CJ5
Originally Posted by uptillnow View Post
Whooops...
UPTILLNOW
learn something new every day.
Unread 08-15-2013, 10:01 AM   #9
swatson454
swatson454's Avatar
1983 CJ7
I wonder what idle speed you can get before exposing the enrichment holes. I bet it isn't much.
Unread 08-15-2013, 10:11 AM   #10
superj
1987 YJ Wrangler
you can put a snorkel on the weber also. redline weber sells a snorkel kit for their webers so if you worry about high water crossings, that is the only kit i have found to put a snorkel on a carb
Unread 08-15-2013, 12:09 PM   #11
John Strenk
1976 CJ5
the Carter BBD I took off a V8 had holes in the throttle plate:
Not exactly something you would need a pin drill to make...
Unread 08-15-2013, 12:53 PM   #12
arkiemurph
Find ya a quadrajet! Small front, big secondaries when you need them, and a good off-road carb.
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline   Reply With Quote
Unread 08-15-2013, 02:08 PM   #13
uptillnow
uptillnow's Avatar
I think you may be onto something here.
The 38-DGES throttle plates "NEED" to be below the enriching holes.
The MC2100 is not as sensitive and could get a little more idle speed than the 38-DGES.
Because you have a 38-DGES, you would be the one to find out the answers to these questions.
Certainly there are bigger carburetors than these, they will work great.
UPTILLNOW
P.S. Drill some holes in the throttle plate like John's picture shows..
(Blasphemy, I tell you.)
Unread 08-15-2013, 05:15 PM   #14
swatson454
swatson454's Avatar
1983 CJ7
I bet that communist trick would work pretty well in this application.
Shawn
Unread 08-15-2013, 05:30 PM   #15
uptillnow
uptillnow's Avatar
i bet that communist trick would work pretty well in this application.
Shawn
lol
