Weber 34 Carb TOO Rich, Possible Solution, Need 2 volunteers - JeepForum.com
post #1 of 20 Old 10-17-2008, 04:47 PM Thread Starter
Fjguercio
1978 CJ7
Hi,
I need two volunteers with Weber 34 too rich
I am looking for 2 JeepForum members that have a newer Weber 34 that is running rich and would be willing to buy a few jets both idle / run install them, adjust the carb, time, as needed and read the plugs to see if this solves your problem. I will help you and have some resourses that can help us also. If this works out well we can post the Jet Range that will work much better for the 258. You need to have a good base 258, rebuilt or not too many miles on it so we get the base line normal. I would prefer that you have some knowledge about your engine and CJ. Also prefer engines that do not have computer operation. Maybe had the stock carb running well and changed to WEber 34 and too rich????
Approx jet cost 4-6 pcs $6 each and you fax your order to WeberDirect.
I have been working with a new WEBER 34/34 DGEC and a 1978 CJ 7 258 with a newly rebuilt engine with 2000 miles on it. I have been in contact with WEberDirect quite a bit, researched everthing I could onthe WEB as for good set ups and trouble shooting. I had/have problems with rich smoking Idle and Runs rich on spark plugs they are black with a sooty coating. I have been changing Jets and upgrading my ignition and have a very good base line. On the lastest run of idle jets no longer smokes and no longer rich on the plugs. Seems to run pretty well now.
I want to post a FUTURE thread that has good knowledge and base set ups. I will use the links that I found, the TEST Results that worked out, so others do not need to pull the "hair out in frustration". This is not the final thread. I am just looking for 2 more testers and have 1 already.
PM your personal email and I will send you a 1 sheet document of what to order and where to fax the order.
Thanks,
Fred
Fjguercio is offline
post #2 of 20 Old 10-18-2008, 10:38 AM Thread Starter
Fjguercio
1978 CJ7
Bump up, any volunteers??
post #3 of 20 Old 10-18-2008, 11:36 PM
CJ559
TOO Rich
Hey new to this forum and would like to help you out with the Weber K551 34 carb. I am running a stock 258 with aftermarket distributor.
CJ559 is offline
post #4 of 20 Old 10-18-2008, 11:50 PM Thread Starter
Fjguercio
1978 CJ7
Welcome to the JeepFourm.
That sounds good. Are you running rich and stinky?? Did you install the carb and are their any changes to the jets and so forth to tune your ride?
If your after market distributor is HEI and recent. There are major problems with the HEI/AMC Engine combination that uses hardened steel gears that can be harder than you cam gear and eat up. Thus no oil, failures????, and metal filings in the engine. MSD and DUI are safe units to buy, but stay away from the cheap crap.
Post or confirm the questions above. Send me your email via a PM at top of the page. I send you a sheet of info.
post #5 of 20 Old 10-19-2008, 09:10 AM
CJ559
Too rich
Rich and stinky. I installed the Carb. The original jets were Idle jet 55 and secondary 47.5.
I swapped the secondary jet and the idle jets. Only a minor improvement.
DUI distributor.
Stock 258 motor with NO SMOG PARTS.
RickGregor@hotmail.com
CJ559 is offline
post #6 of 20 Old 10-19-2008, 06:51 PM
BioTex
1979 CJ7
I'm also running rich, but might be due to elevation I'm at, and linkage not adjusted properly. I just installed the DGEV, and haven't figured it all out yet. I might be a candidate though if it doesn't have to be at sea level.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #7 of 20 Old 10-19-2008, 07:32 PM
Bard
Originally Posted by Fjguercio View Post
Hi,
Thanks,
Fred
Are you running a FPR? It was recommended to run a Holley 12804 when I did mine a couple of years ago.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #8 of 20 Old 10-19-2008, 09:47 PM
KBONSIG
I have the 34/34 - just finishing up my tub swap / rebuild - I ran rich all the time, but cut the cat out since there is no need for it anymore - got to tell you I cranked it up and ran it for the first time in 5 months - not running rich at all. Now I did not drive it at all since I still have to hook up the clutch linkage, but can the free flowing exhaust be helping the cause at all?
2003 TJ RUBICON (CURRENT)
1985 CJ7 I6
2000 TJ I6
1995 YJ 4Cyl
1987 YJ I6
KBONSIG is offline
post #9 of 20 Old 10-20-2008, 01:08 PM Thread Starter
Fjguercio
1978 CJ7
Yes, running the Holey Fuel Pres Regulator, ordered with the Weber 34.
I agree, This FPR should be used with any setup, if the fuel pump is not a 3-3.5 psi output. Do not buy a cheap copy either they do not work.
I am not looking for solutions here.
I am just looking for 2-3 volunteers that want to try a jet change and get this Carb, Weber 34, under control. I have two volunteers and can use 1-2 more max.
Fred
post #10 of 20 Old 10-20-2008, 01:12 PM Thread Starter
Fjguercio
1978 CJ7
I do not think so.... I have a Borla Header and exhaust system w/o catalytic converter. Still rich with the WEber 34 and factory jets. Would be curious to know what Idle & Run jets are in your carb.
Freed
post #11 of 20 Old 10-20-2008, 01:19 PM Thread Starter
Fjguercio
1978 CJ7
You are correct High Elevation can affect the carb settings and jets. IN addition the DGEV you mention is not a Weber 34.
Fred
post #12 of 20 Old 10-20-2008, 03:59 PM
CJ559
Thought you were going to send Info sheet
CJ559 is offline
post #13 of 20 Old 10-20-2008, 10:42 PM
KBONSIG
Freed
Stock Jets.
1985 CJ7 I6
2000 TJ I6
1995 YJ 4Cyl
1987 YJ I6
KBONSIG is offline
post #14 of 20 Old 10-20-2008, 10:55 PM Thread Starter
Fjguercio
1978 CJ7
Dear CJ559,
The sheet was sent to your Email 1:48 pm today. Order your jets, install, email me back and let me know how it goes.
Dear Kbonsig,
I am trying to confirm what Weber 34 has installed for STOCK JETS. I was told these are bench flow tested and have my doubts. If you know what jets Idle & Run are installed stock it could be usefull.
Fred
post #15 of 20 Old 10-20-2008, 11:12 PM
mherois
hey
i would help ya out still but since we last spoke i removed the weber 34 and put on the old carter yf 1 barrel, my distro. was bad too so i had to change that out. im following the post though for after i fix my other issues.
mherois is offline
More questions about weber carb problems... runs rich all the time vking76 Jeep CJ Forum 5 04-29-2010 03:01 PM
Weber 32/36 running rich...too rich! WolfDawg Jeep CJ Forum 36 03-16-2010 07:05 PM
WEBER 34 DGEC Carb TOO RICH??, Jets & Tune for Jeep 4.2 / 258 Fjguercio Jeep CJ Forum 55 05-13-2009 01:14 PM
OK, I got a weber, it's rich at idle. grady adams Jeep CJ Forum 3 11-22-2004 07:53 PM
Weber running really rich. ScottJ Jeep CJ Forum 3 08-05-2004 08:52 AM
